Go to Post Please don't confuse energetic enthusaism with acting obnoxious. - Alan Anderson [more]
Unread 02-06-2010, 10:26 PM
eovnu87435ds eovnu87435ds is offline
FRC #0087
eovnu87435ds has a spectacular aura abouteovnu87435ds has a spectacular aura abouteovnu87435ds has a spectacular aura about
Issues with Classmate Camera Feed
Hey, I am sure there are a hundred threads on this issue, but every one I have visited has been unable to help me solve this problem. I am using LabVIEW, and started with a new default FRC cRIO Robot Project, and just added a few things like servos and solenoids. How do I get the live feed to appear on the classmate?
I have tested the Servo Camera example in LabVIEW, and everything worked perfectly. I also did the 2010 Driver station update(the one that puts the gyro information on the dashboard) and have even tried making a new dashboard application and using it in place of the stock one, but all to no avail.
Anybody have any clue as to what's going on? Is there anything I have to add to the code for it to work?
Any help would be greatly appreciated.
Unread 02-06-2010, 10:32 PM
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
Re: Issues with Classmate Camera Feed
Did you do the labview update, re-image the cRIO with v19, configure the camera with FRC/FRC, and uninstall & reinstall the driver station update?
Unread 02-07-2010, 12:30 AM
FRC #0087
Currently Downloading FRCLabVIEWUpdate2.0for2010.zip
That will update LabVIEW and give us the v19 image?
Unread 02-07-2010, 12:37 AM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Yes.
Unread 02-07-2010, 01:19 AM
FRC #0087
Awesome! I will post the results ASAP
Unread 02-07-2010, 04:58 PM
dwmcc dwmcc is offline
FRC #2192 (YAK Attack)
Team Role: Leadership
dwmcc is an unknown quantity at this point
Angry Re: Issues with Classmate Camera Feed
Yes, please tell us if that works. We (Team 2192) are having the same problem. As you said, everything works fine in the test camera feed project, but when the actual robot code is running, and the Driver Station and PC Dashboard are enabled, we receive the message "Timeout in Camera Communication".
Thanks!
dwmcc
Unread 02-07-2010, 05:00 PM
ideasrule's Avatar
FRC #0610 (Coyotes)
The "timeout in camera communication" can only mean one thing: that you haven't installed updates properly. Do you see a compass on your dashboard?
Unread 02-07-2010, 05:01 PM
Nope. What's that mean?
Unread 02-07-2010, 05:40 PM
Gary.C Gary.C is offline
OUTWORK US
FRC #1323 (MadTown Robotics)
Gary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond repute
Send a message via AIM to Gary.C
If you haven't donwload the DSUpdate1. Download it. Install it. Then Uninstall it. Then reinstall it. The installer has problems. Then click local dashboard on the bottom portion and you should see the new dashboard.
Gary Chahal
Webmaster & Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 02-07-2010, 05:44 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Run the Driver Station update again, this time telling it to uninstall the files. Then run it a final time to reinstall everything. You should then have the updated Dashboard with the working video display and gyro heading indicator.
Unread 02-09-2010, 07:17 PM
Labot2001's Avatar
Labot2001 Labot2001 is offline
FRC #3332
Labot2001 is an unknown quantity at this point
Team 3332 here, we're experiencing the exact same issue.
Anyone know where can I find the download for the DSupdate1 ?
Unread 02-09-2010, 07:28 PM
Pamela Greyer Pamela Greyer is offline
The NASA Lady
FRC #2725 (Ice Princesses)
Team Role: Teacher
Pamela Greyer is an unknown quantity at this point
We're having similar issues with the camera feed. We attended a Labview workshop this past Saturday and did all the steps outlined above and the driver station was working fine including the camera feed. When we turned the driver station on yesterday and nothing. Very aggravating.
Unread 02-09-2010, 07:31 PM
tubadude's Avatar
tubadude tubadude is offline
FRC #2957
tubadude is an unknown quantity at this point
We had the same problem, but as others have said the installers wonky. Uninstall DSupdate1 if you have it and reinstall it again.
Here's the link for the DSupdate1, http://joule.ni.com/nidu/cds/view/p/lang/en/id/1535
Unread 02-09-2010, 08:15 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
  #15   Spotlight this post!
Unread 02-09-2010, 09:35 PM
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
Rookie Year: 2010
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
I know that my mentor Todd can't stress enough, Install the updates. I know once we had those, the camera basically became plug and play.
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
Classmate networking issues byteit101 Programming 5 02-05-2010 06:30 AM
Classmate network issues? aaronhammond11 FRC Control System 5 01-18-2010 01:56 AM
Classmate Issues ROFLcopter NI LabVIEW 10 01-16-2010 09:56 PM
Live Feed with Axis Camera CHSboy Programming 6 03-24-2009 02:43 PM
Target acquisition with camera- color issues Quarkster Programming 20 03-12-2009 12:11 AM
