trouble undeploying default or downloaded code
I need to do some debugging and I am unable to get the downloaded code, whether default or mine, to undeploy. I get the following message when I try:
Unable to delete the UserProgram from the robot The odd part is this used to work (famous last words). I had some trouble from downloading (FIRST->Download) a program that did not clean up its tasks and I had to re-image the cRIO. Since then I've had odd problems. I found some posts on this from last year but they are not helpful. Has anyone encountered this problem this year? |
| Code downloaded but not working... :( | pudgeball | C/C++ | 4 | 28-01-2010 11:04 |
| Undeploying code. NEED HELP | dnrobotics11 | C/C++ | 3 | 01-02-2009 18:33 |
| i downloaded the source code, now what do i do? | programmr | Programming | 2 | 12-12-2008 14:39 |
| Problems integrating CMUCAM code and IFI Default Code | Windward | Programming | 2 | 06-02-2007 16:48 |
| problems using gyro/adc code with camera default code | tanstaafl | Programming | 7 | 22-01-2006 23:09 |
