Go to Post We like playing with power tools, stripping wire, or just stripping for alliance partners... - Amanda Morrison [more]
Unread 07-02-2010, 06:40
Rafael2215 Rafael2215 is offline
FRC #2215
Rafael2215 is an unknown quantity at this point
building an energy conserving pneumatic system
Hi,
We were wondering whether it is possible to build a pneumatic system that conserves the air it's using, meaning that after the first pressurization of the tanks, made by the compressor, there will be no need for any more pressurizations for the remainder of the match, that is you start the compressor only once at the begginnig of the match and stop it when the pressure in the tanks reaches 115 psi (this being achieved by having the same volume of air leaving the piston at one end entering the piston at the other end simultaneously).
If it is possible, can anyone shed some light about how to build such a system?
Thanks,
Team 2215
Unread 07-02-2010, 06:46
martin417's Avatar
martin417 martin417 is online now
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Re: building an energy conserving pneumatic system
What you are describing is perpetual motion, and it is against the law (physical law that is). If you have a very small amount of work you want to to during the match, the initial fill might last, but you can't go forever.
Former Mentor Team 1771
Former mentor Team 4509
Unread 07-02-2010, 10:00
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Use the smallest stroke and bore pistons you can get away with, actuate your pistons at the lowest possible pressure, and if you don't need a huge amount of force to return your pistons consider a second circuit at an even lower pressure to return them, or use spring-return pistons. Also, use tons of leak-check (soapy water) to make sure your system has as few leaks as possible! It is nearly impossible to have a system that's completely leak-free, however.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 07-02-2010, 13:18
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Does not the regulator vent to maintain low side pressure?
Al
WB9UVJ
www.wildstang.org
________________________
Unread 07-02-2010, 13:35
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Al's channeling Yoda
The only type of pneumatic system that doesn't use air would be along the lines of using the air as a spring - such as a pneumatic shock. You would have to use a motor to then wind a load back against the air.
You can't get something for nothing. It's thermodynamics.
Unread 07-02-2010, 13:40
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Annoying answers aside, you can get about 12 shots of a 3/4" diameter, 5"stroke piston before the storage tanks drop below 60psi, starting at 120. So if you need pneumatics to perform a one-time action like lift an arm up, you might not need the compressor.
Edit: for example, to improve efficiency on our kicker mechanism, only 2 of the four pistons are charged to return the kicker, while four are charged to deploy it, reducing air consumption per shot by 25%. We might even dial it down to 1 return piston if that turns out to be adequate.
Unread 07-02-2010, 13:22
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's easy, just make it so that the pneumatic system needs to do no work. That means, don't put any cylinders in it. Then it will maintain pressure.
But if you want the system to move something on the robot, then the air pressure in the storage tanks will drop, and you'll need to refill them with the compressor.
What pneumatics does is use a motor (the compressor) to do work remotely (the cylinder) by using air flow.
If you don't let the air out of the other end of the cylinder then there will be no pressure difference in the cylinder, so the piston won't be able to exert any force.
Unread 07-02-2010, 13:38
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
While physics prevents you from getting more energy out of a system than you put into it, there are ways that you can conserve the energy in a pressurized system by extracting that energy more efficiently.
One example is the double (or triple) expansion steam engine http://en.wikipedia.org/wiki/Steam_e...ansion_engines where the exhaust from the high pressure cylinder is used to feed a lower pressure cylinder. I wouldn't recommend this for an FRC robot's pneumatic system, but it is interesting to know about from a themodynamics standpoint.
Jason
P.S. While I was looking for a good link to explain multiple expansion engines, I stumbled upon this site: http://www.animatedengines.com/index.shtml where someone has taken a lot of time to show off how a number of different engines (including several variations of Stirling Cycle engines) work.
Unread 07-02-2010, 13:43
MrForbes's Avatar
AKA: Jim
I think the "annoying answers" were to this part of the question.
Potential Energy stored in a pneumatic ram Pneumaticsman Pneumatics 20 14-01-2010 22:39
Conserving Energy: Stepping in the Right Direction? thegathering Chit-Chat 5 14-09-2006 14:49
pic: Pneumatic system |_-LuIz-_| Robot Showcase 1 02-03-2005 21:31
[OCCRA]: pneumatic system greencactus3 OCCRA Q&A 1 21-10-2004 15:31
Building a control system Katie Reynolds Technical Discussion 3 16-11-2001 09:34
