Go to Post The trick to designing is to identify the problem before finding a solution. - BJC [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 07-02-2010, 13:58
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Machining fiberglass rods
Team 2745 is exploring the use of flexible fiberglass rods. As a 10 year mentor/coach ( founder 499) I have no experience in drilling or machining fiberglass of any type.
How likely will drilling a hole through the rod cause it to splinter and break?
Are there any fact sheets that would give some guidance such as 0.500 in round stock could accept a 0.128 in through hole axially...
The use of this rod will cause it to flex much in the manner of camping tent poles. I am thinking that a hose clamp will not give sufficient attachment over the course of the season.
As always is the case, any and all advice or suggestions are welcome, espcially from teams using non-traditional materials in their robot construction.
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Acme Threaded Rods and Studs Arkorobotics Technical Discussion 6 01-02-2007 16:48
Aluminum Brazing Rods sanddrag Technical Discussion 2 25-11-2005 12:40
Tetra Rods Steel, not PVC? Matt Adams General Forum 13 10-01-2005 05:15
Fiberglass Keithicus Technical Discussion 2 27-01-2002 04:27
