Connecting Two motors to one Jaguar Controller?
Well, we've been working on setting up our motor drive system and ran into a bit of a problem.
We've been running each motor to a single Jaguar, but now we're thinking one of the Jaguars might have died on us. I've heard varying opinions on this matter, and basically wanted to see if I could get some solid information. Basically, would we be able to run both motors connected to a single Gearbox through a single Jaguar, or do we need two control modules, one for each motor on one side? If we can do this, are there any adverse affects or downfalls, or anything that we should be aware of? If we can consolidate each side to a single Jaguar, I think it'll make everything much easier, but I wanted to see if anyone has experience with this first before we try and push it. Thanks for the time! |
Re: Connecting Two motors to one Jaguar Controller?
One motor per Jaguar.
As Mark pointed out, this would be illegal. Our team thought the same thing, luckily we double checked the manual. If you think that your part is dead, I would suggest a quick order to AndyMark.
It looks like they only have the Black Jaguars in stock. |
The only repurcussion I can think of is that you'll only be able to utilize part of the power of two cims as your electrical power will be limited to ~420watts. Of course it will also be a whole lot easier to pop a single 40Amp breaker with 2 CIMs. |
Aye, but another rule specifically says no.
Long story short, one controller to one motor. Thems the rules, and its the safe way do it. |
It may have been a special exception because some teams, like ours, got FP motors that were only rated to 6v, so running two in series gave you the same current draw at the same voltage as one 12v FP.
you could use a victor, and plus black jaguars can work the same as other jaguars
#10
-dave . |
#11
One motor per controller.
| pic: Jaguar Speed Controller | Padre_Vez | Extra Discussion | 15 | 31-01-2009 14:41 |
| Jaguar Motor Controller Problem | prashil27 | Electrical | 5 | 07-01-2009 21:21 |
| connecting Jaguar to Sidecar | Lakedaimon | Electrical | 2 | 15-12-2008 01:04 |
| Connecting the controller | Max Brin | Technical Discussion | 1 | 12-01-2006 11:24 |
| Connecting FP Motors to stuff | Matt Krass | Motors | 5 | 28-07-2003 17:40 |
