Go to Post BTW don't trust game hint threads started by Greg Needel. - rtfgnow [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 02-08-2010, 02:07 PM
LyraS LyraS is offline
FRC #2102
LyraS is an unknown quantity at this point
Unexpected results from Encoder::GetRate()
I'm trying to set up a speed controller using the US Digital E4P-250-250-D-D-D-B encoder and the WPI Encoder class. Everything basically works fine but I'm seeing an odd discrepency between the values out of GetRate() and GetDistance(). Spinning the encoder at a constant rate, I would expect that the rate returned by GetRate() (units/sec) would more or less match the one-second delta returned by GetDistance(). But what I see is this: the distance returned for one second is almost exactly half of GetRate(). Because GetRate() is fairly noisy, I'm testing using a 20 sample moving average (with a sampling rate of 40hz). I'm sure I'm missing something obvious... Can one of the WPIlib experts here clue me in on what it is? Thanks!
Update, possible clue:
Looking through the WPI source I noticed this comment in Counter.cpp (used by 1x and 2x Encoder):
* Get the Period of the most recent count.
* Returns the time interval of the most recent count. This can be used for velocity calculations
* to determine shaft speed.
* @returns The period of the last two pulses in units of seconds.
double Counter::GetPeriod()
[BB] An unexpected change in plans yodameister General Forum 22 12-01-2009 09:26 PM
Inconsistent reading from encoder get rate rwood359 National Instruments LabVIEW and Data Acquisition 5 01-13-2009 07:10 PM
Results from Drexel, thanks from 365. archiver 2001 1 06-24-2002 02:44 AM
Results from GLR? archiver 2001 0 06-24-2002 02:44 AM
results from regionals archiver 2000 0 06-23-2002 10:31 PM
