Thread Tools |
Rating:
Display Modes |
Displaying Camera Image in C# Dashboard
Dear Cheif Delphi Community,
I know this is a C++ forum, but I dont know anywhere else to post this, but either ways, I am trying to display the camera video on a custom C# form. So far, I have managed to make the the form connect to the camera on the cRIO, and understand that there is data, it even shows the maount of bytes read, ranging from 4(header and size) to 9000(I dont know), this is my current code: Code:
if (netStream.DataAvailable)
image.indicator.Text = "Data Available";
//image.videoStream.Image = Image.FromStream(netStream);
data = new byte[serverClient.ReceiveBufferSize];
bytesRead = netStream.Read(data, 0, serverClient.ReceiveBufferSize);
//tw.WriteLine(DateTime.Now + " " + bytesRead.ToString());
if (bytesRead > 100)
try
MemoryStream ms = new MemoryStream(data);
image.videoStream.Image = Image.FromStream(ms, false, true);
catch (Exception ex)
tw.WriteLine(DateTime.Now + ex.ToString());
else if (!netStream.DataAvailable)
image.indicator.Text = "No Data Available";
Re: Displaying Camera Image in C# Dashboard
the data is not an image stream like the one .Net is expecting. I am not sure what the encoding is, but you will need to (I think) capture the data one frame at a time (yes, manually) and convert that to a .Net Image
That is what it is doing, capture ONE image at a time and displaying it, and netStream is not a .NET Image Stream, it is a network stream, and it reads data from a socket, the only thing remotely related or used for creating the image is data(byte[]) that stores the image data in byte form, MemoryStream ms, which is used to store data and then get the Image form the stream, Image.FromStream(ms); . Like I said before, it also shows that there is data available on the stream, it is just the stupid Image.FromStream() keeps returning an Parameter is Invalid in its exception. I dont know what to do at this point.
I'd recommend looking at the LabVIEW dashboard code, and see if it happens to mention what kind of image its expecting.
From looking at the PCVideoServer source code, it looks like there is a header with the four bytes 0x01, 0x00, 0x00, 0x00, followed by 4 more bytes representing the size of the image as a 32-bit integer. The image is sent as a JPEG.
Code:
success = AxisCamera::GetInstance().CopyJPEG(&imageData, numBytes, imageDataSize);
// Write header to PC
static const char header[4]={1,0,0,0};
int headerSend = write(newPCSock, const_cast<char*>(header), 4);
// Write image length to PC
int lengthSend = write(newPCSock, reinterpret_cast<char*>(&numBytes), 4);
// Write image to PC
int sent = write (newPCSock, imageData, numBytes);
The Dashboard Code from LabVIEW doesnt help at all
, ive read through the whole thing countless times, the PCVideoServer.cpp I have also read through that code,infact I am sitting right in front of it lol, that is why there is a if(readBytes > 1000) code, it makes sure I am not sending the header or imageSize as parameters to the MemoryStream, actually after much testing, i got the image to display at about .01 fps rofl, it updates the image irregularly and it is lagging BEYONG belief, here is my current code for that image processing:Code:
//bytesRead = netStream.Read(data, 0, serverClient.ReceiveBufferSize);
bytesRead = client.Receive(data, 0, serverClient.ReceiveBufferSize, 0);
if (bytesRead > 1000)
try
I would recommend reading 8 bytes first, and look for the 0x01,0x00,0x00,x00 header in the first 4. If that's there, read the length from the next 4 bytes. Then, read in that number of bytes from your networkstream, and pass it into Image.FromStream(). Repeat. |
What I meant was that the data you are giving image.fromstream is NOT in the format it accepts.
ex: asdfghjkl is the image data it expects, and you are sending it something else, like 10000009asdfghjkl or a different encoding (but it should be fine if it is a JPEG) |
I hope you dont mind me asking, but can you give me the example for the code for that, becuase from what I have logged, as in BYTES READ, the amount varies, this what an example would look like, this is from my log file:
Code:
2/9/2010 4:53:35 AM StartStream() 2/9/2010 4:53:35 AM Connecting! 2/9/2010 4:53:35 AM Connected 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 7867 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8009 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8039 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8003 2/9/2010 4:53:36 AM 4384 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 3649 2/9/2010 4:53:36 AM 4 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 7995 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 2032 2/9/2010 4:53:36 AM 6001 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8040 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 6412 2/9/2010 4:53:36 AM 1620 2/9/2010 4:53:36 AM 4384 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 3657 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8041 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8061 2/9/2010 4:53:36 AM 4 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8040 2/9/2010 4:53:36 AM 4384 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 3631 2/9/2010 4:53:36 AM 4 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 7984 2/9/2010 4:53:36 AM 4 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8011 2/9/2010 4:53:36 AM 4 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8033 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8057 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8062 2/9/2010 4:53:36 AM 4 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8084 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 4948 2/9/2010 4:53:36 AM 3128 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8073 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8037 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 8025 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 572 2/9/2010 4:53:36 AM 4380 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 568 2/9/2010 4:53:36 AM 8192 2/9/2010 4:53:36 AM 2329 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 8000 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 7988 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 8002 2/9/2010 4:53:37 AM 4 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 8000 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 8026 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 8017 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 4952 2/9/2010 4:53:37 AM 3053 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 8009 2/9/2010 4:53:37 AM 4384 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 3589 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 572 2/9/2010 4:53:37 AM 7400 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 7926 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 2032 2/9/2010 4:53:37 AM 5880 2/9/2010 4:53:37 AM 4 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 7911 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 7954 2/9/2010 4:53:37 AM 4 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 7905 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 6412 2/9/2010 4:53:37 AM 1515 2/9/2010 4:53:37 AM 5785 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 2108 2/9/2010 4:53:37 AM 4 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 7842 2/9/2010 4:53:37 AM 4384 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 3438 2/9/2010 4:53:37 AM 4 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 7828 2/9/2010 4:53:37 AM 4380 2/9/2010 4:53:37 AM 4380 2/9/2010 4:53:37 AM 7300 2/9/2010 4:53:37 AM 4384 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 3361 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 7676 2/9/2010 4:53:37 AM 8 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 7656 2/9/2010 4:53:37 AM 4384 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 3187 2/9/2010 4:53:37 AM 4 2/9/2010 4:53:37 AM 8192 2/9/2010 4:53:37 AM 7611 2/9/2010 4:53:38 AM 4 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 7574 2/9/2010 4:53:38 AM 4380 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 3255 2/9/2010 4:53:38 AM 4384 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 3259 2/9/2010 4:53:38 AM 4384 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 3321 2/9/2010 4:53:38 AM 4384 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 2028 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 747 2/9/2010 4:53:38 AM 4384 2/9/2010 4:53:38 AM 4380 2/9/2010 4:53:38 AM 7229 2/9/2010 4:53:38 AM 4 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 7908 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 7895 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 572 2/9/2010 4:53:38 AM 7201 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 2032 2/9/2010 4:53:38 AM 4380 2/9/2010 4:53:38 AM 1305 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 7646 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 7553 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 7481 2/9/2010 4:53:38 AM 4 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 7335 2/9/2010 4:53:38 AM 4384 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 2860 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 7272 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 4952 2/9/2010 4:53:38 AM 2333 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 7233 2/9/2010 4:53:38 AM 4 2/9/2010 4:53:38 AM 8192 2/9/2010 4:53:38 AM 7198 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 7137 2/9/2010 4:53:39 AM 4 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 685 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 3488 2/9/2010 4:53:39 AM 5840 2/9/2010 4:53:39 AM 1814 2/9/2010 4:53:39 AM 4380 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 1766 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 568 2/9/2010 4:53:39 AM 5664 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 6239 2/9/2010 4:53:39 AM 4 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 6213 2/9/2010 4:53:39 AM 4 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 6330 2/9/2010 4:53:39 AM 4384 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 2058 2/9/2010 4:53:39 AM 4380 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 2055 2/9/2010 4:53:39 AM 4 2/9/2010 4:53:39 AM 4380 2/9/2010 4:53:39 AM 4380 2/9/2010 4:53:39 AM 5916 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 2032 2/9/2010 4:53:39 AM 4522 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 6799 2/9/2010 4:53:39 AM 4384 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 2769 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 7424 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 7716 2/9/2010 4:53:39 AM 4 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 7880 2/9/2010 4:53:39 AM 4384 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 3548 2/9/2010 4:53:39 AM 4384 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 3523 2/9/2010 4:53:39 AM 4384 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 3544 2/9/2010 4:53:39 AM 4 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 7927 2/9/2010 4:53:39 AM 4 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 7917 2/9/2010 4:53:39 AM 4 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 7926 2/9/2010 4:53:39 AM 4 2/9/2010 4:53:39 AM 4380 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 3526 2/9/2010 4:53:39 AM 8192 2/9/2010 4:53:39 AM 6408 2/9/2010 4:53:40 AM 4380 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 5071 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 6408 2/9/2010 4:53:40 AM 1520 2/9/2010 4:53:40 AM 4 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 4948 2/9/2010 4:53:40 AM 2999 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 7915 2/9/2010 4:53:40 AM 4384 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 3566 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 7934 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 7942 2/9/2010 4:53:40 AM 4 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 7949 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 7984 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 2032 2/9/2010 4:53:40 AM 4380 2/9/2010 4:53:40 AM 1543 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 7942 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 4952 2/9/2010 4:53:40 AM 3031 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 3488 2/9/2010 4:53:40 AM 4464 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 4948 2/9/2010 4:53:40 AM 3016 2/9/2010 4:53:40 AM 4380 2/9/2010 4:53:40 AM 4380 2/9/2010 4:53:40 AM 7416 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 7957 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 3492 2/9/2010 4:53:40 AM 4488 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 4948 2/9/2010 4:53:40 AM 3051 2/9/2010 4:53:40 AM 8192 2/9/2010 4:53:40 AM 2028 2/9/2010 4:53:40 AM 5926 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7974 2/9/2010 4:53:41 AM 8 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7734 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 3492 2/9/2010 4:53:41 AM 4510 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7868 2/9/2010 4:53:41 AM 90 2/9/2010 4:53:41 AM 4380 2/9/2010 4:53:41 AM 4380 2/9/2010 4:53:41 AM 7442 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 4948 2/9/2010 4:53:41 AM 2989 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7868 2/9/2010 4:53:41 AM 135 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7868 2/9/2010 4:53:41 AM 101 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 8013 2/9/2010 4:53:41 AM 4 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7992 2/9/2010 4:53:41 AM 4 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 2028 2/9/2010 4:53:41 AM 4380 2/9/2010 4:53:41 AM 1558 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7991 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7956 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7970 2/9/2010 4:53:41 AM 4 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7978 2/9/2010 4:53:41 AM 4 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7976 2/9/2010 4:53:41 AM 4 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 6408 2/9/2010 4:53:41 AM 1576 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7970 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 2032 2/9/2010 4:53:41 AM 5905 2/9/2010 4:53:41 AM 4 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7977 2/9/2010 4:53:41 AM 4 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7973 2/9/2010 4:53:41 AM 4384 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 3563 2/9/2010 4:53:41 AM 4 2/9/2010 4:53:41 AM 8192 2/9/2010 4:53:41 AM 7962 2/9/2010 4:53:42 AM 4384 2/9/2010 4:53:42 AM 8192 2/9/2010 4:53:42 AM 3590 2/9/2010 4:53:42 AM 8192 2/9/2010 4:53:42 AM 572 2/9/2010 4:53:42 AM 7396 2/9/2010 4:53:42 AM 8192 2/9/2010 4:53:42 AM 8017 2/9/2010 4:53:42 AM 4384 2/9/2010 4:53:42 AM 8192 2/9/2010 4:53:42 AM 3634 Last edited by PranavSathy : 08-02-2010 at 16:54. |
#10
depending on the image, the size varies, because JPEG is a compressed format
for example, a pure black image will be much smaller than a picture where every pixel is a different color Edit: look at the attachment sizes Last edited by byteit101 : 08-02-2010 at 17:02. Reason: added sample |
#11
Ok, even with a code that just read 8 bytes at a time, not a single string that I printed into the log had a NUMBER or a 0x00 or whatever the header was, they were all messed up jumbles of characters. I honestly am stuck here, as the image displays once and then doesnot update for anotehr few minutes, then updates, few minutes, one more frame, few minutes, one more frame etc. on and on.
#12
look at it in a byte array, you should see a 1 then 0 0 0 etc...
in a string, this would be a box followed by \0\0\0 (but only in the debugger, output is cut by \0 |
| Labview Dashboard not displaying camera. | GunfighterJ | NI LabVIEW | 1 | 02-02-2010 19:20 |
| Reinstall of dashboard doesn't fix camera image streaming | ellisk | Programming | 2 | 20-01-2010 08:04 |
| [Help Needed] Camera to Dashboard | basicxman | C/C++ | 1 | 19-01-2010 18:20 |
| Can we use the camera image on Dashboard this year? | Jon236 | Programming | 1 | 11-01-2010 12:52 |
| Only Camera works in Dashboard | keehun | Programming | 1 | 06-01-2009 07:22 |
