Go to Post There are simply not enough words to say how much the contributions of Dave and Woodie have given to FIRST, and countless students across the world. - Libby K [more]
Unread 08-02-2010, 15:49
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Labview "File Permissions" Error Win 7
Im using labview on Windows 7 and have been having an error when i try to build a program... in the build prompt it shows the following under the description of the error:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 8 occurred at Create Folder in Create Directory Recursive.vi->AB_Dest_LLB.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW: File permission error. You do not have the correct permissions for the file.
C:\Documents and Settings\Administrator
im sure its more of a windows thing than a labview thing, but could anyone lead me in the right direction on how to get rid of this error? thanks
Question about updating "ni-rt.ini" file to use NetConsole Randy Forgaard General Forum 2 25-02-2010 01:54
"Battery: No Code" after uploading .out file to cRIO knine143 FRC Control System 1 20-12-2008 22:14
"Error.MCP" file after HEX file trans iwdu15 Programming 1 24-01-2007 20:05
On compile: "Coff file format for 'ifi_library.o' is out of date." Ethulin Programming 11 17-01-2007 18:03
IFI Loader problem - "Invalid HEX file" wun Programming 9 22-09-2004 12:35
