Go to Post FIRST Championships event is not about winning, its about the experience, the atmosphere, the people and the sites, there are a lot of amazing things to see at The Championships. - Mike Schroeder [more]
Unread 08-02-2010, 15:49
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
void RobotDrive::SetLeftRightMotorSpeeds?
Hi all-
Our robot drive-train is consisting of a total of 6 motors, meaning 3 motors per side, meaning 3 jaguars per side.
After looking through the RobotDrive class, I noticed there is not consturctor for a 6 wheel drive-train. So I made a constructor for 6 wheels, which I think should work...
Code:
RobotDrive::RobotDrive(SpeedController *rearLeftMotor, SpeedController *middleLeftMotor,
						SpeedController *frontLeftMotor, SpeedController *rearRightMotor,
						SpeedController *middleRightMotor,
						SpeedController *frontRightMotor,
						float sensitivity)
	if (frontLeftMotor == NULL || middleLeftMotor == NULL || rearLeftMotor == NULL || frontRightMotor == NULL || frontMiddleMotor == NULL|| rearRightMotor == NULL)
		wpi_fatal(NullParameter);
		m_frontLeftMotor = m_rearLeftMotor = m_frontRightMotor = m_rearRightMotor = NULL;
		return;
	m_rearLeftMotor = rearLeftMotor;
	m_middleLeftMotor = middleLeftMotor;
	m_frontLeftMotor = frontLeftMotor;
	m_rearRightMotor = rearRightMotor;
	m_middleRightMotor = middleLeftMotor;
	m_frontRightMotor = frontRightMotor;
	m_sensitivity = sensitivity;
	for (INT32 i=0; i < kMaxNumberOfMotors; i++)
		m_invertedMotors[i] = 1;
	m_deleteSpeedControllers = false;
Anyway, I looked into the TankDrive function I am using, because I want to ensure that when I move my joysticks, it moves all the motors, not just the first 2. So after looking through the TankDrive, it calls another function called SetLeftRightMotorSpeeds. After reading that, it makes me THINK that it will only set the first 2 Jaguars (on each side) to drive, not the third.
Here is that function
Code:
void RobotDrive::SetLeftRightMotorSpeeds(float leftSpeed, float rightSpeed)
	wpi_assert(m_rearLeftMotor != NULL && m_rearRightMotor != NULL);
	leftSpeed = Limit(leftSpeed);
	rightSpeed = Limit(rightSpeed);
	if (m_frontLeftMotor != NULL)
		m_frontLeftMotor->Set(Limit(leftSpeed) * m_invertedMotors[kFrontLeftMotor]);
	m_rearLeftMotor->Set(Limit(leftSpeed) * m_invertedMotors[kRearLeftMotor]);
	if (m_frontRightMotor != NULL)
		m_frontRightMotor->Set(-Limit(rightSpeed) * m_invertedMotors[kFrontRightMotor]);
	m_rearRightMotor->Set(-Limit(rightSpeed) * m_invertedMotors[kRearRightMotor]);
Any help on how to edit that so all 3 will go, not just 2?
Edit: Im thinking i can just say m_middleRight/LeftMotor -> Set...., but Im not sure.
Thanks- 1771
Unread 08-02-2010, 15:59
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: void RobotDrive::SetLeftRightMotorSpeeds?
The simple and obvious solution is to duplicate the lines that control the front motors and change them to control the middle motors.
(But I'm not as strong in C++ as I could be, so keep in mind this adage: For every complex problem, there is usually a solution that is simple, obvious...and wrong.)
Unread 08-02-2010, 16:18
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
Yeah, that's why I'm hesitant to do that.
One of those reasons is that first If statement is corresponding to the set command directly below it, but the next Set command is not....
I figure I can just try it, with the motors not hooked up, and just check the Jags.
Unread 08-02-2010, 16:54
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
but it is correct:
(change the 1 to -1 to invert the middle motors)
Code:
	if (m_middleRightMotor != NULL)
		m_middleRightMotor ->Set(-Limit(rightSpeed) * 1);
	if (m_middleLeftMotor != NULL)
		m_middleLeftMotor ->Set(Limit(leftSpeed) * 1);
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 09-02-2010, 10:33
JacobC's Avatar
JacobC JacobC is offline
FRC #1885 (ILITE Robotics)
Rookie Year: 2007
JacobC is an unknown quantity at this point
I believe there is a reason that there is not a six wheel drive train option. To my knowledge, you are only allowed to use 5 CIMs. I would double check the rules on this before spending too much time programming it.
Unread 09-02-2010, 10:47
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You are correct that only 5 CIMs are allowed. However, it's likely that they are using 4 CIMs and 2 other motors (such as fisher price motors).
RobotDrive Bug? Bryscus Programming 5 03-02-2010 10:29
RobotDrive + PIDController = possible? oddjob C/C++ 4 14-01-2010 23:33
editing robotDrive class help mikelowry C/C++ 2 07-10-2009 13:25
void* pointer to object in C++ byteit101 C/C++ 6 14-01-2009 17:15
problem with void Process_Data_From_Local_IO CmptrGk Programming 2 29-01-2005 17:14
