sim motor wires?
we noticed that our Sim motors have size 14 wires, but r47 a and b say that you can't have a wire above 12 gauge,the 40 amp fuse requires 12 gauge wire but since the Sim motors have 14 gauge so the Sim motors have been unqualified for it, and so the robots should have been disqualified for the past 4 years.
Can anyone help with this problem? I"m really confused. thanks! |
Re: sim motor wires?
The rule applies to PDB branch circuits. I'm not sure that a motor-Jag/Victor connection is counted as part of PDB branch circuit. I do remember somebody asking about it in the past; it wouldn't hurt to ask Q&A this year and get the official response again. (And, a note to any GDC member reading this--it probably wouldn't hurt to include a specific explanation about this in the rules next year.)
The wire size minimums were written with the short length of CIM motor wires taken into account. The wire used in the CIM motor has a higher temperature insulation that wire generally available.
However, Gold Star for having been the first to notice this discrepancy in quite a while. |
I think most of the teams noticed it, but we just ignore it as it's been that way for the past few years. Anyway, no one that showed up would be able to play if they didn't allow it
. As fixing the leads requires disassembling and modifying the CIM, which is against the rules also. |
FIRST must be conservative when choosing wire sizes that teams must use, but that's why a smaller wire could be used based on the insulation. Last edited by Joe Ross : 20-02-2010 at 01:00. |
There is a little fudge factor in there as well. The temperature rise and voltage drop are used to generate wire tables. As the voltage drop for a few inches of the CIM motor wire is small and temperature of the wire in air is different (lower) than the wire in conduit, there can be a little derating when comparing to standard wire tables. Add to that the series resistance of the speed controller and the final current will be lower at the motor wiring.
| Attaching a gear to a SIM motor | aceshigh2729 | Technical Discussion | 8 | 09-02-2010 02:03 |
| Virtual sim | Brandon_L | General Forum | 5 | 27-01-2009 21:50 |
| Blue Drill Motor wires? | j_pannell | Electrical | 4 | 17-02-2004 15:06 |
| Please help asap.. Where do the victor motor 3 pin wires plug into | 1166 | Electrical | 10 | 16-02-2004 12:07 |
| update 8 clarification, drill motor and blue wires | pryoplasm | Rules/Strategy | 23 | 13-02-2004 07:26 |
