Go to Post Needless to say, lots of smoke came out, and I debated using its terrible smell as a deterrent. - Snapshot [more]
Unread 08-02-2010, 23:12
Lumit Lumit is offline
FRC #2521
Lumit is an unknown quantity at this point
Joystick-Servo control
So we want to have the servos on the camera mount controlled by a joystick.
our camera mount: http://andymark.biz/am-0568.html
I have a feeling the issue is our number range conversion.
As I understand it, the joystick axes output a value of -127 to 127.
And the servos can use 0 to 1 (with set position) or 0 to 180 (with set angle).
So I added 127 to the joystick input, then divided it by 255, then fed that value into the set position VI. When powered up, it locks itself facing straight upwards, and wont respond to the joystick.
Am I missing something? It feels mathematically solid yet it isn't working!
thanks
Unread 08-02-2010, 23:21
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Joystick-Servo control
If you use Joystick Get, the joystick value is -1 to 1.
Use that with Servo Set Position.
Just feed it directly for your first test without any mathematical manipulation.
Labview Servo Control Issue EricWilliams Programming 5 22-01-2010 14:24
Camera servo control off of the Joystick axes m3rc1l3ss NI LabVIEW 5 13-03-2009 20:00
1 Joystick Control penguain Programming 9 01-02-2008 10:02
Servo Control? mattg101 Technical Discussion 2 20-01-2007 13:12
Direct control of a Servo or Speed Controller Schmitty! National Instruments LabVIEW and Data Acquisition 3 06-03-2006 13:53
