Go to Post I tried to convince my team to use the force but no one would listen. - ngreen [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 09-02-2010, 02:50
Bob Holmstrom Bob Holmstrom is offline
FRC #2411
Bob Holmstrom is an unknown quantity at this point
NXT Ultrasound sensor?
Has anyone tried to use the NXT ultrasound sensor? Does a Labview/FRC vi exist for the sensor?
Thanks for any help!
Bob Holmstrom
Mentor Team 2411
Unread 09-02-2010, 08:23
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: NXT Ultrasound sensor?
It isn't an I2C standard sensor, so you'd have to find some other way of interfacing it.
Unread 09-02-2010, 15:08
FRC #2411
OK - There is a ultrasonic vi in the example code provided that uses a sensor labeled SRF04 - There seems to be quite a number of ultrasonic sensors out there that use that part number, but the information at http://www.acroname.com/robotics/inf...h/srf.html#e11 that describes the devantech SRF04 and SRF05 seems to resemble the information in the ultrasonic VI. Has anyone used this sensors in a FRC application?
Bob Holmström
Unread 09-02-2010, 18:18
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Mark,
Actually, the NXT ultrasound is I2C. You may be confusing this with the VEX ultrasound which is not (it's discrete digital).
Hopefully, this document should give you everything you need.
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
[FTC]: NXT-G programming ivybotter FIRST Tech Challenge 4 10-10-2009 12:02
Frozen NXT Brick. devinejohnny General Forum 2 05-11-2008 21:34
Lego MindStorm NXT Gamer930 Lego Mindstorm Discussion 1 10-07-2006 09:21
pilot NXT opportunity RoboMom FIRST Lego League 0 08-05-2006 10:32
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
