LabVIEW/Jaguar Help
The Software has been updated. The cRIO has been updated. The instructions were followed to the letter for implementing Simple Motor Control. The program compiles and downloads without an error. Under the "Watch Mode" everything functions without an error. However, the Joystick does not cause the motor to run and the Jaguar flashes yellow (never going solid).
All of the wires have been tested for continuity. All parts have been systematically swapped out. Does anyone have any suggestions/help as to why the Jaguar never goes solid and the motor doesn't turn? We can't go any further until we resolve this issue. bhenze@sapulpaps.org |
Re: LabVIEW/Jaguar Help
What is the RSL on the Digital sidecar signaling?
And the other Digital Sidecar power status lights? What do all the Driver Station status lights on the Diagnostics tab indicate? Of course, is your robot Enabled? Some typical reasons for a Jaguar blinking yellow:
Did you mean to say you are using the "Motor Control Example" ? My version of LabVIEW doesn't have a "Simple Motor Control" example, but you might be using something else as your baseline. What instructions did you follow, so I can walk through them? Last edited by Mark McLeod : 09-02-2010 at 10:11. |
Finally, all the right questions fell into place - it is now working - Thanks!!!!
A brief explanation of what you did to make it work would be appreciated.
| labview delay help | glitch | NI LabVIEW | 3 | 08-02-2010 09:37 |
| Labview help | pedro696 | General Forum | 14 | 06-02-2010 19:34 |
| HELP!!!! we need help w/ compressors/pneumatics for teleop/autonomous in LABVIEW | rokenboker | NI LabVIEW | 9 | 05-02-2010 17:10 |
| labview comressor help!! | mole | NI LabVIEW | 15 | 03-02-2009 14:11 |
| help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) | liad | LabView and Data Acquisition | 8 | 18-01-2006 12:20 |
