"Painting" on the field
When our robot turns it leaves sort of "drift marks" on the field.
Is it legal? |
Re: "Painting" on the field
I think it is illegal. Sorry. One of the rules states, and i am paraphrasing, the robot cannot do anything that damages or alters the field in anyway
You need to figure out if you are damaging the carpet or leaving any residue behind. If your marks just come from changing the angle of the fibers in the carpet so they reflect light differently (kind of like you see with the rolled grass patterns on baseball fields) then you are probably fine.
If you are leaving a trail of burned rubber and molten carpet in your path you should consider changing something. Check for tears or fibers in the carpet that are pulled out. Also be sure you are not leaving peices of your wheels behind. Those are the kinds of things that will make your inspection difficult. Good luck! Rob |
Roy,
Is the residue that same color as your wheels or are you merely rubbing off surface contamination? |
Just to add to the discussion a bit, some carpet damage over the course of a regional from robots tipping, hard defense, etc... I don't think I've ever been to an event where the carpet didn't have a scrape or ten on it by the end of eliminations.
But, if the Damage is ruled as intentional, or due to the design of your robot you probably will not pass inspection or you will be carded sometime during your event. I'd say that leaving skid marks on the carpet under normal conditions is illegal. |
| What's the difference between "The Great Attractor" and "Dark Flow" | Woody1458 | NASA Discussion | 0 | 04-05-2009 22:17 |
| Championship Event - Where the "Random" Match Sorting Really "Shines" | Travis Hoffman | Championship Event | 57 | 19-04-2007 08:06 |
| "Thunderbirds" Vs. "Team America" Which one will rule the box office? | Elgin Clock | Chit-Chat | 3 | 07-09-2004 19:53 |
| Is the "sort by uploader" supposed to work in the "who am I" gallery? | Greg Ross | CD Forum Support | 1 | 07-10-2002 07:05 |
| how tall is the ramp when in "up" and "balanced" position??? | archiver | 2001 | 1 | 24-06-2002 00:54 |
