Go to Post Our team has a forum..... chiefdelphi.com Ok I had to say it. - Mike Martus [more]
Unread 09-02-2010, 18:11
ninjamonkey29 ninjamonkey29 is offline
FRC #2523
ninjamonkey29 is an unknown quantity at this point
Robot Crashes with voltage spike
Well, here it is week 4 and we are still having issues with running our robot....
Every time that we run our 4 wheels (with 4 motors, tank drive) in the required direction to turn in place to the left (left wheels back, right wheels forward) our robot crashes. The motors suddenly hit full speed, and then we can no longer control them. According to the Drivers Station, we are still enabled, and our program continues to print to the modual in wind river. The four jaguars go to their flashing orange light and will not allow control until it is re-enabled from the Driver Station or we reboot the robot. This happens both in Autonomous and Teleop. The speed of the motors does not influence whether or not it crashes. It also will sometimes happen when we move the right joystick forward or when we move the left stick backwithout moving the other, but will always happen if we do both at once. It does not happen when we turn in place to the right, only left. We have measued the output of the Jaguars. When running normally, at full speed they output 11.7-11.85v. When it crashes, it spikes to 12.05 before control is cut.
Here's what we have tried so far to find the source of the problem:
- It does this with LabView and C++, so we assume it is a hardware problem.
- Unplugging the motors from the jaguar motors doesn't make a difference.
- It will still crash when all but 1 jaguar has its pwm cable removed (We don't try all 4 as we then have no way to see if it has crashed or not).
- We have tried replacing the SideCar to no avail.
Any ideas why we are getting this crash + voltage spike?
Festo Wiring with a spike drewjones13 Pneumatics 10 10-04-2008 07:29
Using a spike with a VEX controller? AdamHeard VEX 2 20-11-2007 10:26
Lowering the voltage on a spike Mr. E Programming 16 27-02-2007 17:41
using SPIKE relay module with Fisher Price motors 1574aviad Motors 4 27-01-2005 01:49
Window Motor With Spike/Victor supergrover Control System 9 30-01-2004 15:38
