Go to Post They were designed that way so they would be compatible with the water-based ga.... oops, sorry, we aren't supposed to say anything about that. Never mind. - dlavery [more]
Unread 02-09-2010, 06:55 PM
Lord_Jeremy's Avatar
Lord_Jeremy Lord_Jeremy is offline
Lord_Jeremy the Procrastinator
AKA: Jeremy Agostino
FRC #1546 (Chaos Inc.)
Team Role: Electrical
Rookie Year: 2007
Lord_Jeremy is an unknown quantity at this point
Send a message via ICQ to Lord_Jeremy Send a message via AIM to Lord_Jeremy Send a message via MSN to Lord_Jeremy Send a message via Yahoo to Lord_Jeremy
Camera not functioning
Right so 1546 has been having a few issues with our camera. We're using Java and I've written a substantial amount of code, including camera routines. Just to test out the hookup and see our advisor's face on the screen, I created the example CircleTrackerDemo project and loaded it on the robot. Alas, the code loaded up and we got green lights across the board but the classmate still showed "Timeout in Camera Communications". I tried rebooting the bot and the classmate, tickng the video button, checking the camera power and crossover cable. Then I made some modifications to the demo code to print to the dashboard if it found a target or not. I didn't get any output at all (yes I called update) which seems to indicate that cam.freshImage() was never true. I even added another print to make sure the display worked. Read elsewhere that we might try reinstalling the DS software but it seems to me that this is a camera coms issue. Not sure what to do next. Thanks!
Compiling...
Compiling...
120 psi Main Relief Valve not functioning Clifford Pneumatics 10 02-11-2008 10:29 PM
Camera not powered...? Total Meltdown Programming 7 01-14-2006 01:54 AM
Functioning 1/4 Scale V8 engine! sanddrag Technical Discussion 8 02-26-2005 10:39 PM
firstawards website functioning? Lisa Perez General Forum 5 02-16-2005 06:41 PM
