Go to Post Hmmm I think I hear phones ringing. Panic calls to the Rules committee to figure out how to close THAT loophole, which you could drive a truck through. Have you considered a career in Law? - ChrisH [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 09-02-2010, 19:09
berngannon berngannon is offline
FLL #8846
berngannon is an unknown quantity at this point
Question [FTC]: Field Controller System Problem
hi,
when we launch the field controller sytems we get everything to work, btooth, cntrl pad but it won't let us setup the teleop file name, won't browse, says file not found.
help
we can get themechanic to work in labview but nothing outputs when we set up teleop in labview w/ motor config setups good and btooth running
hard to program with no communication to motors
help
Unread 09-02-2010, 20:25
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
Re: [FTC]: Field Controller System Problem
Teams using LabVIEW select their TeleOp program by running a program on the NXT called "Program Chooser." The Program Chooser writes a text file to the NXT named "FTCConfig.txt." This file contains the name of the team's TeleOp program.
The Program Chooser is installed on the NXT the first time the LabVIEW FTC Controller Station is used with the NXT. The FTC Controller Station is part of the LabView install package. The default path to the FTC Controller Station is:
C:\Program Files\National Instruments\LabVIEW 2009\examples\FTC Toolkit\FTC Controller Station\FTC Controller Station.exe
The Field Control System (FCS) program that teams use to control robots during matches at tournaments reads the name of the TeleOp program from the FTCConfig.txt file. The FCS does not have the capability to add or change the name of the TeleOp program.
[FTC]: Field Control System jamie_1930 FIRST Tech Challenge 10 27-11-2009 10:09
[FTC]: Bluetooth Problem with LabView/FTC Controller Station James Dowd FIRST Tech Challenge 8 27-10-2009 10:40
[FTC]: Field Management System KayyPii FIRST Tech Challenge 9 19-02-2009 10:26
[FTC]: Problem with two controller setup in Labview wilsonmw04 FIRST Tech Challenge 2 11-11-2008 19:58
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
