We Got Mech Shifting But We Need help with Regular TURNING
![]() we tried using arcade drive but the wheels are inverted any help or is there something im missing? |
Re: We Got Mech Shifting But We Need help with Regular TURNING
Look at your wheels. Do they form an X or an O pattern? When viewed from above or below? (ex. "X from above" "O from below")
it shows a x from above
Describe in English how you want the spin controlled (what joysticks, buttons, etc.) and we may be able to help you implement it in Labview. |
then when we press button 1 it will do shifting/crabbing |
It sounds like your problem is with your false case. What does your false case look like right now and what problems are you having with it? Your first post mentions that "the wheels are inverted", but I'm not sure what this means. |
our false only has arcade in it; is there a better or am i doing it wrong?
OK, so what is the problem you are experiencing? What does "the wheels are inverted" mean?
when we go forward the left side goes backwards
#10
Are you sure that you have the correct axis wired into the correct terminal on the Arcade Drive VI?
That's the only thing I can think of. If you didn't properly invert the motors when opening the drive in Begin.VI I don't think your holonomic VI would drive and strafe properly. |
| Regular Xbox Controller...HELP! | lostandconfused | Control System | 1 | 13-02-2007 14:29 |
| Need shifting transmission layouts/ideas | sanddrag | Technical Discussion | 6 | 13-01-2006 13:24 |
| Turning problems, we need suggestions PLZ | Oumonkey | Technical Discussion | 44 | 20-07-2005 12:21 |
| New to C but not to basic, need help on autonomous | cdennisxlx2 | Programming | 4 | 02-02-2005 03:38 |
| hey need some help with writing a code please help me here | magical hands | Programming | 9 | 01-01-2004 21:46 |
