Go to Post Wait - a single message outlining the vast majority of where to find controls stuff? Goodness. What will they think of next. - Tom Line [more]
Unread 09-02-2010, 19:49
Jake The Man Jake The Man is offline
FRC #2655
Jake The Man is an unknown quantity at this point
Problem with servo control
I need to have a Servo be controlled by a throttle. I have confirmed that the throttle works properly but it refuses to move the servo. How do I get this to work? Do i use the set position or set angle VI? Thank you
Unread 09-02-2010, 22:08
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Problem with servo control
Use Set Position, because it's inputs are similar to a throttle's outputs, not exactly the same, but workable for testing.
You should be able to wire axis 3 (if that's what the throttle is) directly into the Servo Set Position.
The Set Angle is looking for a completely different kind of value. Check the context help for details on what both of these expect as inputs.
Unread 09-02-2010, 23:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Also be sure to install the 6v power jumper for the PWM output that is connected to the servo.
Problem Getting Victors to run with the new control system Boommaster713 Programming 11 15-02-2010 15:29
Joystick-Servo control Lumit NI LabVIEW 1 08-02-2010 23:21
Team 2102 Problem With Control Interface kevinbrice Control System 15 16-10-2009 23:56
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
Servo Control? mattg101 Technical Discussion 2 20-01-2007 13:12
