Go to Post Sounds fun? Maybe only if you're a giant dork, but I'm a pretty giant dork, so... - Madison [more]
Unread 02-09-2010, 11:17 PM
DWirth DWirth is offline
FRC #2509
DWirth is an unknown quantity at this point
Running Motor for X Milliseconds
Hello,
I'm working on programming our kicker which our team would like to wind up at certain tensions. To do this, I want to have the CIM motor to run for a certain amount of milliseconds if one button is pressed on the joystick. It would be nice if I could use a couple different buttons for different times. Then use a limit switch to tell the motor so stop all the way back no matter what time I select. However, I am not sure how to make the motor set speed vi to run continuously for a set amount of time. Does anyone have any ideas on how I can achieve that? Thanks for your help.
Dillon Wirth
Unread 02-09-2010, 11:51 PM
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: Running Motor for X Milliseconds
I just posted a reply in a different thread that almost applies to your situation.
It's not exactly what you're looking for, but it involves writing code that runs in TeleOp, but takes longer than the 20msec main-loop time. It involves using shift registers to provide feedback from loop-to-loop in your teleop routines.
Here's a link to that thread.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 02-10-2010, 07:54 AM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
It sounds like what you want is in three parts. First, start a motor running forward when a button is pressed. Second, stop the motor a certain amount of time after the motor is started. Third, if the motor isn't running forward, run it backward until a limit switch activates. Is that right?
You'll need a "rising edge detector" to find the start of the button press. Then you'll want something that runs the motor until a certain time has elapsed. The attached code fragment shows a way to do that.
I'll leave it up to you to figure out how to make the motor run the other way only when it's not being told to run forward and the limit switch is not active.
MIG welder feed motor always running sanddrag Electrical 14 09-11-2006 09:46 AM
DC Motor running as a Generator IrisLab Motors 16 01-12-2004 12:23 PM
A vampire running for office MissInformation Chit-Chat 2 08-30-2003 02:36 PM
Running a motor for a set time in auton Morgoth Programming 5 03-11-2003 01:59 PM
