Go to Post Now stop reading CD, do your homework, eat your peas, brush your teeth, and go to bed. Any time you spend speculating as to what Dave's ravings might mean is completely wasted. - Richard Wallace [more]
Unread 09-02-2010, 23:56
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Rookie Year: 1999
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
8020 vs. Bosch
Hi Everyone,
I could use some expert opinion on the difference between 8020 and Bosch extrusions. I am looking specifically at the 30-30 (mm) series.
Check out the attached pdf for a quick comparison between the two brands' profile in AutoCAD. Then take a look at the different dimensions between the two brands' t-nuts.
We are having difficulties with our local Bosch distributor, and are considering switching to 8020 instead. Are there any advantages/disadvantages one way or another?
-Ken L
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 10-02-2010, 00:42
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
Re: 8020 vs. Bosch
Originally Posted by Ken Leung View Post
Hi Everyone,
-Ken L
I've never used bosch, but my team has used 8020 many a time. We are using two short pieces on this year's bot.
We have always purchased the 8020 from a certain supplier in San Jose. I don't remember the name, but if you're interested I can talk to the other team 100 mentors who have been there. I recommend this place specifically because they keep 8020 in stock and you can go and pick it up in a day.
Be careful about ordering online or through one of 8020s distributors. Some of them are horrible and take forever.
As for fasteners, team 100 uses 1/4-20 carriage bolts. It so happens that the heads slide perfectly into the slots, and the square part prevents them from spinning. So instead of threading in a bolt you can screw on a lock-nut.
Biscuits and drop-ins will drive you crazy . Not to mention that they have a habit of falling out! Locknuts solve this problem.
Save yourself some sanity, time, and money and buy carriage bolts from your local OSH.
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 10-02-2010, 00:47
Dare to Live!
Rookie Year: 1999
Re: 8020 vs. Bosch
I know the Eppersons also purchased 8020 from a supplier in San Jose. I would really appreciate if you can found out who the supplier is for me.
Also, forgot to ask this in the original post, but I am hopping someone can clarify the compatibility between the two brands. Specifically, if I have Bosch extrusions now, can I use 8020 hardware/t-nuts on the Bosch extrusions? Other about vice-versa?
The profiles and t-nut dimensions suggest they should be fine either way.
Unread 10-02-2010, 01:52
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: 8020 vs. Bosch
When I was on 100 and we used 8020 we used toilet bolts in place of t-nuts in a lot of situations. Much cheaper and like Martin said, you can use lock nuts.
You still want a pretty healthy supply of drop in t-nuts because you'll always want to add something later that you didn't foresee.
At the time I think a somewhat local supplier (maybe Sacramento?) was giving FIRST teams a discount on 8020. That was about 7 years ago now though, so I'm not sure if they still do.
T nuts should fit equally well in either profile.
2001-2004: Team 100
2006-Present: Team 254
8020 Mass Tanner Inventor 16 23-01-2010 10:24
pic: What goes on those 8020 Rails?? Thermal Extra Discussion 7 10-01-2009 08:12
pic: 8020 Chain Tensioning idea Andy L Extra Discussion 12 03-11-2008 16:08
Bosch or 80/20? Nate Laverdure Technical Discussion 8 22-01-2007 21:54
Bosch Pinion JamesJones Motors 18 23-02-2003 00:20
