Go to Post I think CD is worth about 3 billion in Google stock. Talk about one hell of a fundraiser! - Joe Matt [more]
Unread 10-02-2010, 00:49
joecap5 joecap5 is offline
FRC #0181
joecap5 is an unknown quantity at this point
Should the encoder example work right out of the box?
I uploaded the encoder example code to the robot without any modifications. When we spin the encoder (4EP) the distance indicator continually jumps between .25 and 0.
Has anyone else had this problem?
Unread 10-02-2010, 00:55
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Should the encoder example work right out of the box?
It sounds to me like you only have have one of the encoder signals wired.
Unread 10-02-2010, 01:11
FRC #0181
Both signals are wired. We tried three different encoders and all three have the same problem.
We got them working last year.
Unread 10-02-2010, 08:54
FRC #0181
I'm using the example Labview encoder vi.
Unread 10-02-2010, 10:48
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I agree with Joe Ross. This is exactly the symptom you would get from an encoder opened as 4x with only one of the two phases attached. Can you tell us exactly how you have the encoder connected? Which wires go to which pins on the Digital Sidecar?
Unread 10-02-2010, 19:41
FRC #0181
I don't have it in front of me right now, but I believe I have the wires in the following order: brown red blue, ground power signal. These go into DIO 1. I have channel B, the yellow wire, going into DIO 2.
Thanks for the help.
Unread 12-02-2010, 00:48
FRC #0181
So after days of trying to figure this out we finally found the problem.
One of the CRIO modules is broken, but just a little. It does everything except read the DIOs. So we swapped it out and now everything works.
Can't run BuiltInDefaultCode out of the box? whytheheckme Java 14 18-01-2010 01:19
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Need a little help with how to break out of the box amateurrobotguy Programming 6 16-01-2006 12:56
Out of the box Fundraising... trollin1st Fundraising 10 15-09-2005 19:50
