Go to Post Cooler robots = Impressed sponsors = More money for FIRST = Easier expansion = Easier culture change. Isn't this what we want? - Karthik [more]
Unread 10-02-2010, 11:39
oddjob oddjob is offline
Rookie Year: 2007
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
DriverStationEnhancedIO compile error
I copied this out of WPI_Robotics_Library_Users_Guide.pdf and put it in the constructor:
Code:
    DriverStationEnhancedIO &dseio = DriverStation.GetInstance().GetEnhancedIO();
Here is the compile error:
Code:
C:/WindRiver/workspace/BuiltinDefaultCode/BuiltinDefaultCode.cpp: In constructor `BuiltinDefaultCode::BuiltinDefaultCode()':
C:/WindRiver/workspace/BuiltinDefaultCode/BuiltinDefaultCode.cpp:99: error: expected primary-expression before '.' token
C:/WindRiver/vxworks-6.3/target/h/WPILib/DriverStationEnhancedIO.h:127: error: `virtual DriverStationEnhancedIO::~DriverStationEnhancedIO()' is private
C:/WindRiver/workspace/BuiltinDefaultCode/BuiltinDefaultCode.cpp:99: error: within this context
C:/WindRiver/workspace/BuiltinDefaultCode/BuiltinDefaultCode.cpp:99: warning: unused variable 'dseio'
C:\WindRiver\vxworks-6.3\host\x86-win32\bin\make.exe: *** [BuiltinDefaultCode_partialImage/Debug/Objects/BuiltinDefaultCode/BuiltinDefaultCode.o] Error 1
Is the pdf file wrong, or I did something wrong?
Unread 10-02-2010, 16:51
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: DriverStationEnhancedIO compile error
I think this means the PDF is incorrect.
It should look more like this:
Code:
DriverStationEnhancedIO &dseio = DriverStation::GetInstance()->GetEnhancedIO();
DriverStation::GetInstance() returns a pointer, so it is necessary to use ->.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 10-02-2010, 18:59
Rookie Year: 2007
Thanks. This now compiles but I can't test it tonight due to snow closing:
Code:
  DriverStationEnhancedIO *m_dseio;
  m_dseio = &DriverStation::GetInstance()->GetEnhancedIO();
Is there somewhere to report documentation errors? It would be great to get the pdf's fixed.
[FTC]: Compile error saaby FIRST Tech Challenge 3 17-02-2009 17:14
MPLAB Compile Error with MPLIB GRS Programming 2 04-11-2008 10:31
compile error Chuck Merja Programming 3 17-02-2005 15:02
InterruptVectorLow error when we compile Redneck Programming 5 02-02-2005 22:57
Compile error blindguyinanorg Programming 4 12-02-2004 19:49
