Go to Post A robot that can't move isn't a robot. It's just furniture. - John Neun [more]
Unread 10-02-2010, 12:01
jeser#1772's Avatar
jeser#1772 jeser#1772 is offline
1772 and 4613
FRC #4613 (The Brazilian Trail Blazers and Barker RedBacks)
Team Role: Coach
jeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond reputejeser#1772 has a reputation beyond repute
Send a message via MSN to jeser#1772
pic: #1772 robot
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Team Role: Leadership
Rookie Year: 2007
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Re: pic: #1772 robot
Very nice looking package. Good luck this year!
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 10-02-2010, 15:45
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
That's some nice machining! =O I especially like the labeling of the Bumper Zone.
Just one little thing. It looks like your drive shafts stick past the frame? I think that was ruled to be in violation of the frame perimeter rules (even if it falls within the 28x38 rules).
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 10-02-2010, 23:29
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
I believe those would be considered "minor extrusions"
Unread 10-02-2010, 23:32
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Yes, but there is no rule that allows minor protrusions to stick out of a vertical projection of the FRAME PERIMETER if they are not inside the BUMPER ZONE.
The frame as pictured, appears like it may have a problem with <R16>
Unread 10-02-2010, 23:34
_Tanto_'s Avatar
_Tanto_ _Tanto_ is offline
_Tanto_ is an unknown quantity at this point
Very nice! ... are you guys capable of going under the bump or are you a little too tall?
"a triscuit can only do what a triscuit does"
ChrisP's Avatar
ChrisP ChrisP is offline
AKA: lil'C
ChrisP will become famous soon enoughChrisP will become famous soon enough
I like your 6 wheel drive design, and the compact size of your robot suggests that you will be going under the bump, a good plan indeed. All in all, good job!
Big C here to help!
Unread 11-02-2010, 08:02
jeser#1772's Avatar
1772 and 4613
Team Role: Coach
hello
thanks the replies guys!
the bumper zone has 1/2 inch more than the rest
and the max perimeter is 16' x 23' x 31
1772 - The Brazilian Trail Blazers
4613 - Barker RedBacks
Unread 11-02-2010, 08:24
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Water-jet FTW?
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 11-02-2010, 08:29
jeser#1772's Avatar
1772 and 4613
Team Role: Coach
laser cut...
Unread 11-02-2010, 09:59
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Well it was one of the two
Unread 11-02-2010, 12:45
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Originally Posted by jeser#1772 View Post
hello
Very nice! That's one good looking machine right there.
pic: Summer Robot- The robot mattd7591 Extra Discussion 2 10-09-2008 08:39
pic: 233 robot teaser, yep, theres our robot ; ) ducttapedude Extra Discussion 20 15-02-2007 22:02
Brazilian Team #1772 Needs Victors misiuk Electrical 2 24-01-2006 14:20
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
