Go to Post This is an engineering competition. Do some. - JVN [more]
Unread 10-02-2010, 13:16
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
Rookie Year: 2010
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Exclamation Routing Camera output via the cRIO
Greetings!
I've come across something related to the Axis camera that I thought I'd pass along. First, if you allow the Axis camera to get its IP address via DHCP, the default IP gateway is listed as 192.168.0.1. This gateway doesn't exist. So, camera output via a standard web browser will not be possible. Either fix the DHCP assignment on the cRIO or setup the Axis to use the 192.168.0.3 address of the cRIO as its gateway via a static IP assignment.
Next comes the magic. On the cRIO, there is a special variable called "ipforwarding" that controls whether the cRIO forwards packets across the 2 Ethernets. Setting that variable to "1", enables IP forwarding. So from a VxWorks shell or via the cRIO console port:
-> ipforwarding=1
will enable the ability to use a standard browser to see and monitor the camera video without the use of the dashboard.
To make this permanent, you'll need to either create an application that sets that variable (remember it's an "extern") or add the ipforwarding=1 command to a script of some sort.
HTH,
Mike
Unread 10-02-2010, 15:52
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Re: Routing Camera output via the cRIO
we need static routes in the driver station router also?
Unread 10-02-2010, 16:16
Software Mentor
AKA: Mike Anderson
Rookie Year: 2010
Yes, you'll need to add a route to the Classmate to be able to get to the Axis camera as well. In WinDoze from a DOS cmd box:
route add 192.168.0.0 mask 255.255.255.0 10.xx.yy.2 metric 3 -p
The xx.yy is your team number e.g., Team 116 would be 10.1.16.2. The metric of 3 allows it to go through 3 hops to get to the camera. It's one more than you need, but this allows you to attach a secondary laptop to the Classmate via a USB Ethernet and display the output on the secondary PC. Since the Classmate appears to be having trouble keeping up with the video, this is a good option that is still within the rules.
The final "-p" makes this route persistent across reboots. I.e., you won't have to enter this route again on the Classmate.
HTH.
Unread 26-03-2016, 13:26
bdleppke bdleppke is offline
FRC #1731
bdleppke is an unknown quantity at this point
Interesting - thanks for posting. Is this still valid for the 2015/2016 crio? We have a static IP address on our Axis camera and we would like to be able to connect to the web page of the camera from the driver station laptop while tethered with the USB.
Brent
Unread 28-03-2016, 11:13
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Please clarify if you are discussing the cRIO or the roboRIO as they (as well as the control system surrounding both components) are nothing alike.
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
crio dashboard GPIO output darkorbit Programming 8 09-02-2010 15:29
cRIO output problem alex42 FRC Control System 1 27-01-2010 22:28
cRIO output files aoconnor Programming 2 09-02-2009 17:59
Axis camera without the cRIO CrazyCarl461 NI LabVIEW 12 17-01-2009 10:53
moving via camera input DanDon Programming 1 20-01-2005 20:12
