Go to Post Don't try to kiss your stapler remover, those prongs are sharp... - MissInformation [more]
Unread 11-02-2010, 15:34
Wen1992 Wen1992 is offline
FRC #3324
Wen1992 is an unknown quantity at this point
Problems with Encoder
Our team is trying to use an encoder to measure the amount of times our motor turns so we can adjust our kicker during the match. I have no clue first off how to get the encoder to count in labview and second i am trying to set a limit switch in the encoder so that i can then set it to only wind till a certain position. IE Position 1 to Position 3 or 1 to 2 or 2 to 1. Any help?
Unread 11-02-2010, 15:44
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: Problems with Encoder
You need to create an Encoder object from the WPILib stuff. Then you start it, and use Get to get the value. Reset will reset it.
You could for instance then do something like run a motor until encoder get returns 10, or 100 or whatever.
Unread 11-02-2010, 16:05
FRC #3324
Thanks, but I'm curious how you wire the "get" to find the information and I am completely and unequivocally confused of how to set a limit in the encoder as a switch that we can use to judge where the kicker is at. Any Help?
Encoder problems Pausert NI LabVIEW 3 18-01-2010 12:33
Problems with the KoP Encoder tbd Sensors 2 01-02-2009 15:31
Problems with Encoder Counting bjimster1 Programming 19 07-03-2007 09:59
Encoder Problems bjimster1 Programming 2 10-02-2007 08:04
