Go to Post Ahhh... the beauty of an exponential series... - dtengineering [more]
Unread 11-02-2010, 19:44
Lukos Lukos is offline
FRC #1678
Lukos is an unknown quantity at this point
Bumper diameter compulsory?
My team had some pool noodles donated, but when we checked the diameters, they were all 2"-2.25" rather than 2.5" Is this acceptable, or do we need to go buy more?
Unread 11-02-2010, 19:47
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
Re: Bumper diameter compulsory?
You're probably OK with 2.25 inch ones because a tolerance isn't given in the spec and the pool noodles will be permanently covered and are therefore not likely to be inspected for diameter. The 2.00 inch diameter ones will probably not fill the bumper cloth well enough to be fully effective and might be detectable by inspectors.
Unread 11-02-2010, 23:23
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Maybe do it like this from a side view
Two noodles and half a noodle between, that should get you closer to the dimension needed.
[NOTE]Not sure if the inspectors would get you on this.[NOTE]
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 11-02-2010, 23:32
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I think they would. <R07-C> specifies a "stacked pair", not a stack of pool noodle parts that is 5" high.
I would also ask Q&A what tolerances there are on the noodles--i.e., is being short a quarter inch on the diameter allowable or not.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 12-02-2010, 07:55
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Lukos,
C. BUMPERS must use a stacked pair of 2˝ inch “pool noodles” as the bumper cushion material.
These were chosen due to the availability of the raw material and it's ability to protect 150 lb robots. The 2" that you are speaking of may not be made of the same material, as a matter of fact that they may be pipe insulation or something else. These would not protect your robot from damage and more importantly would not protect other robots from contact with yours. I suggest you go find a regulation pool noodle and compare it to what you have received as a donation. Inspectors are asked to at least squeeze a bumper to know what is inside.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 12-02-2010, 14:21
FRC #1678
Yeah, they're pool noodles, but from Wal-Mart, so they're cheap. The outside diameters are 2.5" at the ends, but not anywhere else... We're probably going to get some from Target or some other place.
Unread 12-02-2010, 14:24
Unsung FIRST Hero
Rookie Year: 1996
Lukos,
Try measuring at different angles around the outside diameter. They may be the legal material but are out of round/elongated from improper storage. If they are 2.5 at the ends, I am betting they are 2.5 in the middle when formed into a circle.
Al
WB9UVJ
www.wildstang.org
Unread 12-02-2010, 14:31
College Mentor
AKA: Trent Borman
Al is probably right, we have some old pool noodles that got chucked in a crate with the lazy susan and some rods from previous KOPs we never used and now it keeps its deformed shape very well.
If it feels like a "regulation/standard" pool noodle and is similar in that the hole is .5" in the middle I would guess it would be fine, if it does seem to get thinner in the middle maybe contemplate adding a little bit extra in the middle area.
Unread 12-02-2010, 14:38
Unsung FIRST Hero
Rookie Year: 1996
I should have added that a hair dryer used to slightly heat the noodle that is flattened can allow it to reshape to it's former diameter.
Al
WB9UVJ
www.wildstang.org
Unread 13-02-2010, 01:08
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I just got pool noodles of the correct diameter at Target's here in CT. In case anyone's looking for them, perhaps other stores in the chain will have them too.
Unread 13-02-2010, 12:42
FRC #1678
yeah, I just checked target, and they had nothing... Target seems pretty hit-or-miss with things like this
80 inch diameter? Pneumaticsman Technical Discussion 4 15-01-2008 08:54
[OCCRA]: diameter mikaela50 OCCRA Q&A 1 28-09-2005 19:34
Goal Diameter Bremma Technical Discussion 2 13-01-2004 06:23
Pipe Diameter archiver 2001 1 23-06-2002 23:45
