Go to Post Well, air conditioners when pointed inside the house make it cooler. So I figure if EVERYONE turns their air conditioners on full blast and just point them out the window, we should more or less get rid of this "warming" nonsense. - Mike [more]
Unread 11-02-2010, 19:44
dancola1 dancola1 is offline
dancola1 is an unknown quantity at this point
Mecanum Help Needed
So we have been working on the Mecanum code since the kickoff and we are still having problems. Currently we can only make the robot go forward and backward. If we press the three button on our logitech Extreme 3D pro joystick it rotates like it is suppose to.
The problem is that we can not get it to crab/strafe or rotate when we twist our joystick.
Attached is two pictures of our teleop.vi when button three is pressed "true" and when it is not pressed "False".
Please help us fix this vi so we can move on to our other code.
thanks.
Unread 11-02-2010, 20:55
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Mecanum Help Needed
take a look here for explanation of commands for mecanum:
http://www.chiefdelphi.com/forums/showpost.php?p=916383
Unread 11-02-2010, 21:05
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
look for a subvi in the pallet called rectangle to polar which will combine your x and y vectors in to magnitude and phase(direction)
Unread 11-02-2010, 21:46
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Spoiler alert only go to this picture as a last resort it shows exactly the working holonomic drive (with a Logitech Dual Action Controller(you should only need to change the axes))
It is better to learn through testing and trying things out rather than copying. I repeat last resort only.
Name:	Working Mecanum Drive.PNG
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 12-02-2010, 12:00
robot.lords robot.lords is offline
FRC #2485
robot.lords is an unknown quantity at this point
What is this block? I can't find it in the palletes. (from your code, dana)
Unread 12-02-2010, 12:10
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
That block VI called In Range and Coerce and can be found in the Comparison palette. It takes in 2 values that set a range (in this case 1 and -1) and a third value to compare. The VI tests whether the value is i the range, then outputs a True/False of whether it was in the range or not (In Range) and a value forced into the range (Coerce).
What this means is that if you put something in larger than 1 you will get out 1, if you put something in between 1 and -1 it will pass through unchanged and if you put in something smaller than -1 you will get out -1.
Unread 13-02-2010, 00:11
FRC #0379
Here's the pwm outputs (in begin.vi)
Mecanum Wheel Setup Help Dylan5019 NI LabVIEW 16 10-02-2011 15:39
Mecanum help in labview. Sam2197 NI LabVIEW 1 08-02-2010 18:59
Holonomic vs Mecanum Help!! kSniper Technical Discussion 10 25-03-2008 16:57
Mecanum Programming Help Mars Programming 8 27-02-2008 15:41
Mecanum Drive - Help Smoking_Gun Programming 22 04-12-2007 20:51
