Go to Post 6 months huh? That's about the last time I posted heavily on this site (April). Don't make me come back & whip all of you back into shape people! :yikes: - Elgin Clock [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 11-02-2010, 19:45
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Jaguar freezing
Our team is trying out the CAN interface to see if it would work for competition. The code is a simple get Y-axis on the joystick and set the voltage % to that (voltage mode btw). While running, after a bit of time the motor freezes for a split second and the black jag light goes to flashing yellow. The elapsed time counter on the driver station also freezes for this period of time. No errors are reported over Netconsole or the diagnostics window. The classmate is directly connected to the cRIO w/ a crossover cable. This problem gets worse as the time using the robot goes up. Any help would be appreciated
Terminal window freezing? Alan Anderson Programming 6 04-02-2008 10:11
Accelerometer and Gyroscope freezing in EasyC Jennymcf Programming 0 01-02-2008 22:57
Labview freezing constantly Smithvillefirst NI LabVIEW 1 20-02-2006 20:30
Labview keeps freezing SHerpich LabView and Data Acquisition 31 02-02-2006 14:53
Problem with freezing frames in LabVIEW pdc LabView and Data Acquisition 2 26-01-2006 01:34
