Go to Post Yes, it is fun. Its fun to watch the students expand their thinking and look outside the "normal" and watch their thoughts explode! Its also fun to watch the mentor's minds fry trying to out think the students.;) - Robert Cawthon [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 11-02-2010, 23:18
taysonholzer taysonholzer is offline
FRC #2484
taysonholzer is an unknown quantity at this point
Camera Difficulties
We're using the Axis camera provided in the Kit of Parts, but we're having problems displaying the image on the Classmate. We have completed the following:
Set IP address of camera to 10.24.84.100 (we are team 2484)
Set Subnet mask of camera to 255.0.0.0
Hooked camera with a crossover cable into ethernet port 2 of the cRIO
Copied sample code (windriver/c) for camera into program
We're getting great communication with the cRIO, but no image is displayed. Can someone help us out?
Unread 12-02-2010, 00:03
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: Camera Difficulties
Make sure you've download the mandatory updates from the USFIRST website and installed them on the classmate AND reimaged the Crio with the Version 19 image that comes with that update.
In addition, the installer doesn't work correctly, so you'll need to install the update on the classmate, uninstall it, then reinstall it again to insure that you have it correctly installed.
The easiest way to tell if you have the update installed correctly is to look for a "compass" to the right of the camera image on the dashboard. If it's there, you've installed correctly.
Unread 12-02-2010, 00:05
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The camera IP needs to be left at the default of 192.168.0.90 for anything to work.
It also needs a user account of username:FRC/ password: FRC.
Unread 13-02-2010, 13:27
FRC #2484
We have installed the new updates, but it was mentioned that they must be installed, uninstalled, and then reinstalled again. We can't figure out how to uninstall these updates so that we can reinstall them again.
Unread 13-02-2010, 14:04
Just Itinerant
If your Dashboard looks like the right picture here:
http://www.chiefdelphi.com/forums/sh...1&postcount=12
then you don't have to worry about running the installer again.
If it looks like the left photo, then run the DSUpdate again and see this photo for where the uninstall is:
http://www.chiefdelphi.com/forums/at...8&d=1264826428
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
make sure your dashboard is updated(has a gyro indicator)
if not update it and the camera feed should work
4WD Turning Difficulties dtengineering Technical Discussion 106 15-01-2009 17:12
IR Difficulties AmitCarmeli Programming 3 11-01-2008 20:49
Technical Difficulties muy dificil Programming 0 13-10-2005 11:25
Default Code Difficulties Drok00 Programming 3 02-02-2005 20:56
