Go to Post I've managed to convince my wife that Valentine's Day is February 24th. :) - dtengineering [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 12-02-2010, 01:19
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
Question CANJaguar for C++: Missing mode init messages?
This is really a question for Joe, because I know he's most likely lurking around these parts , but if anyone else knows the answer, please chime in.
We are planning to use Speed mode on our Jags (2Can-driven). I was reviewing the latest CANJaguar.cpp code (from FIRSTForge source), and noticed that in the InitJaguar() method, there is a switch statement that sends a control mode initialization message to the Jaguar. However, this is only done for Voltage mode, and no others.
My question: Is this an oversight, or do the other control modes indeed require no initialization message? I compared against the Java code, and in there, an init message is sent for each mode.
Like I said, we are "planning" to use Speed mode (still getting our encoders hooked up), otherwise I would just test this out to see if it actually makes a difference. I assume that someone else already has, and so if you have, did you have to change the C++ code to add in the init for the other modes?
Thanks in advance for any help!
TeleOp Init/Stop vs. Auton-Iterative Init/Stop Ziaholic NI LabVIEW 11 07-02-2010 22:19
CANJaguar + BlackJagBridge plugin errors Shinigami2057 CAN 1 06-02-2010 11:20
Wierd basic init Jeremy J Programming 5 06-02-2003 11:42
Basic Init Error yan184 Programming 5 14-12-2002 13:10
