Go to Post This looks like a job for duct tape! - JoeXIII'007 [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 12-02-2010, 13:27
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Speed direction in CAN?
When using quadrature encoders directly connected to the Jaguars, we noticed that the speed returned over CAN is always positive, whichever direction the wheel rotates. We see this both via our Java code and using the BDC-COMM utility.
This causes difficulty running closed loop since the signs of the PID values would depend on the wheel direction, and I'd rather not change PID values on the fly to avoid possible instability.
The most likely explanation is that we made a wiring error and are only getting a single A or B channel from all of our wheel encoders - I won't be able to check until tomorrow - but I'd like to confirm that the Jaguar firmware is working correctly.
So has anyone successfully seen a negative speed returned over CAN from a Jaguar?
How can you figure out robot speed?!?! gnirts Programming 7 01-04-2006 13:05
Edit- Can we connect more than one speed controller fan per breaker? DemonYawgmoth Rules/Strategy 7 03-02-2006 21:37
Can we use old Relays and Speed Controllers? thoughtful Control System 14 17-01-2005 14:55
Can we use old Relays and Speed Controllers? thoughtful Electrical 14 17-01-2005 14:55
Need direction...... archiver 2001 0 24-06-2002 02:17
