Go to Post So, if you feel your team is at a disadvantage, or the playing field isn't level.... Do something about it. - AdamHeard [more]
Unread 12-02-2010, 13:35
salomon90's Avatar
salomon90 salomon90 is offline
AKA: Bryan
None #0005 (GO FIRST)
salomon90 is on a distinguished road
pic: Part of the control board along with the bump
Unread 12-02-2010, 13:37
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: pic: Part of the control board along with the bump
It's hard to tell from the picture, but those wires on your jaguars look awfully small (assuming they're for 40A fuses). Make sure you're following the wiring size rules.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-02-2010, 14:33
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Agreed, though our wires look pretty thin as well because they have a thin very hard jacket as opposed to the thick silicone jackets from the KOP
Also, when you transfer it to your competition robot, keep the wires well labeled and strapped down well so you can more easily diagnose problems.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 12-02-2010, 14:35
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Bryan,
This picture is a classic example that I would use when demonstrating a different approach to robot wiring. Long, small wires will not give you the power you might expect from CIM and FP motors. The wire produces series resistance that lower the available power from this high current motors. However, a few minor changes can make huge improvements. By placing the PD in the center of your board, you shorten the path length between the PD and speed controllers. By then placing speed controllers near the motors they will control, you shorten the path again. I would guess that your robot like most, will be running four motors. If they are close to each other, then place the controllers close enough to the motors that you won't have to add any wire to the motor. If you have two motors on the front and two motors on the back of your robot then place the speed controllers in a like manner, two in front and two in back. This simple rearrangement of parts will cut 6-8 feet of wire out of your design, make things much neater and give you maximum power from your drive motors. If you use #10 wire instead of #12, you will cut the series resistance in half.
The Crio and the sidecars can be placed anywhere that might convenient (or for COG weight distribution) as they do not draw significant currents nor do they produce signals that are affected by long runs.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 12-02-2010, 14:40
MPG's Avatar
MPG MPG is offline
Tutu Man
AKA: Michael
FRC #1259 (Paradigm Shift)
Team Role: Electrical
Rookie Year: 2007
MPG is an unknown quantity at this point
It looks to me as if your board is made out of aluminum, if this is the case you are probably going to want to rethink this. You will want to mount you electronics, most important the cRIO on a nonconductive surface. This will minimize the possibility of a static shock that would kill your electronics.
Team Robot Names
2010 = Oswald
2009 = Black Magic
2008 = Barnaby Rover
2007 = Z
2006 = Dilbert
2005 = Oder
2004 = Gerry
Unread 12-02-2010, 20:16
Phreadumb's Avatar
Phreadumb Phreadumb is offline
FRC 2188 Alumnus
AKA: Dakotah Jones
Phreadumb has a spectacular aura aboutPhreadumb has a spectacular aura about
Actually, a metallic surface reduces Electromagnetic Interference.
I will be trekking into territories where FIRST teams do not exist, perhaps I should start one? Oh, but that's a lot of work.
Unread 12-02-2010, 20:25
Unsung FIRST Hero
Rookie Year: 1996
Actually, aluminum isn't as good as materials containing iron, nickel and a few others. However, it is as good as any metal at conducting static charge/discharge. Sometimes the offending signal passes through a device, reflects off the metal and returns through the device. Sometimes the whole shooting match acts as an antenna and that could be good or bad depending on if you wanted an antenna.
Let me reiterate, the Crio and the camera both have their chassis connected to the negative terminal of the battery through the power cable. Both need to be insulated from the robot frame.
<R43> All wiring and electrical devices, including all control system components, shall be electrically isolated from the ROBOT frame. The ROBOT frame must not be used to carry electrical current (e.g. this is necessary due to polarity reversals that occur under certain operating conditions such as during motor direction reversals).
Al
WB9UVJ
www.wildstang.org
Unread 12-02-2010, 21:23
longrange longrange is offline
FRC #1070 (Royal Robotrons)
longrange is an unknown quantity at this point
Solomon90 it looks like you are only using 1 40amp breaker. The CIM and Fisher Price motors can draw a lot of current when starting up, climbing a burm or pushing another robot. You're probably using 4 of these high current draw motors which should be protected by 40 amp breakers. As mentioned earlier check out rule R47A for the appropriate wire size. Good luck and have fun!!!
Unread 12-02-2010, 22:26
Unsung FIRST Hero
Rookie Year: 1996
Uh, looks like 5 40 amp plus one 20 feeding the sidecar and one not connected.
Al
WB9UVJ
www.wildstang.org
2481 Drives Over the Bump with Mecanum Wheels kylelanman Robot Showcase 13 02-02-2010 00:53
Do we have to ship the control system along with the robot on Tuesday? tennisbeast29 Rules/Strategy 3 14-02-2009 13:39
Pics along with the avatar FF_1610_EMT Chit-Chat 2 07-03-2008 11:34
pic: The Rolling Control Board Of DOOM!!!!! zakk Extra Discussion 10 15-04-2007 01:55
IT'S ALIVE!!!!!!! WE WILL CONQUER THE WORLD WITH THESE!!!!!! (Part 2) THE MOVIE sgsdragons Robot Showcase 20 16-02-2006 10:46
