Go to Post ...playing hard and impressing teams is way more valuable than trying to play god with the rankings. - JamesBrown [more]
Unread 12-02-2010, 13:58
Puffin's Avatar
Puffin Puffin is offline
FRC #2625 (Arc Angels)
Rookie Year: 2010
Puffin is an unknown quantity at this point
Send a message via MSN to Puffin
Post Axis Camera limitations
Hi everyone.
I just wanted to ask what kind of limitations are there for the Axis Camera included with the kit?
I heard it can ONLY be used in Autonomous mode and it CANNOT be used in Tele op mode.
Is this true?
Unread 12-02-2010, 14:01
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: Axis Camera limitations
Untrue. Can be used anytime.
Unread 12-02-2010, 14:37
Puffin's Avatar
Rookie Year: 2010
What!!?? Where did you read that?? I read on this other thread that FIRST was going to disable the cameras due to bandwidth limit....
Unread 12-02-2010, 14:42
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
first limits the bandwidth but that doesn't mewan you cant use the camera, it just means if you plan on seeing the image from teh camera, it will not be a high resolution or fps
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Check the age on the thread, live streaming of camera images to the Dashboard was disabled last year (2009) to allow time for FIRST to fully test the affect of the streams on the wireless setup used in competition.
There is no such restriction in place this year. I believe this has been confirmed with the Q&A, but I don't have time to dig the thread up at the moment.
Unread 12-02-2010, 15:06
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I heard...
I read on this other thread...
Hearsay is not reliable. The correct sources of information are the Game Manual, the Team Updates, and the FIRST Q&A forum. If someone says something about the rules without pointing you to an official source, ask them to back up what they say.
The camera falls under the custom electronic device category. The manual does not restrict when the robot may use such devices.
Unread 12-02-2010, 15:12
Puffin's Avatar
Rookie Year: 2010
ok thanks guys! That information really helped
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Axis Camera ehochstein Programming 2 21-02-2009 00:16
Model of Axis Camera Bochek CAD 2 18-01-2009 17:50
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
Camera Limitations? (are there any?) Leav FRC Control System 3 27-04-2008 02:15
