Go to Post They have obviously figuered out something special. I want to learn from them. - dlavery [more]
Unread 12-02-2010, 16:46
mcristina444 mcristina444 is offline
FRC #2078 (Robotic Ooze)
mcristina444 is an unknown quantity at this point
Exclamation Camera servo
im trying to move the camera using the 2nd joytick. we want to make button 8 make it go left and button 9 go right. then for up and down we want the thing that is between them to make it go up and down. anyone know how to do this?
Unread 12-02-2010, 17:12
Re: Camera servo
I think there was a thread that went into details on this recently. Basically you want to set the servo to a value each time through the loop. In front of this, you take the values sent last time and optionally increment, decrement, or leave alone. The value also needs to be remembered again until the next teleop message. The value can be fed back using a feedback node, it can use a shift register, a local variable, or even a global variable.
Greg McKaskle
Unread 12-02-2010, 21:49
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Camera servo
The servo itself remembers its value, so you can just Get Position, add to or subtract from it, and Set Position each time through.
Unread 12-02-2010, 22:15
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: Camera servo
The "thing" between buttons 8 & 9 is called the Throttle ... a.k.a Axis-3.
It goes from -1 to 1 ... but IMO, it goes the wrong way. You can wire the Axis3 (throttle) axis directly into the Tilt servo's SET POSITION. You might want to throw a "negate" in between if it acts backwards.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 13-02-2010, 00:11
umangv620 umangv620 is offline
Programming Captain
AKA: Umang
FRC #1403 (Cougar Robotics)
umangv620 will become famous soon enoughumangv620 will become famous soon enough
Re: Camera servo
That is actually a good idea! I never knew that little thing on the front of the joystick was Axis 3.
btw(by the way), i created a post JUST like this, but I have code that does work(with the lightbulb on). I am still trying to figure out why the camera servo itself isnt working when we deploy the code.
Team 1403 Cougar Robotics
2009-2011 Programming Captain
2010
NJ-Regional - Chairmans Award
Unread 13-02-2010, 00:53
Re: Camera servo
Thanks for all the quick replies! sorry i cant take screen shots of the programming i have already done. what i basically set up was button 8 going into a case structure. (in true) i called up the Get angle then added 10 to it the put that value into Set Angle. it showed a red dot at Set angle. we deployed this code and nothing happened. is there a way to fix the red dot or should we use another Vi such as Set Position and Get position?
Also i did get the Throttle to work. all we added was a negate because it was backwards.
Again thanks for all the help. This is the second year I have been on the team and i am already the head programmer on my team.
Unread 13-02-2010, 08:35
Software Architect
Re: Camera servo
The dot is because Get Angle provides an unsigned 16 bit integer, and Set Angle wants a signed 32 bit integer. They are compatible, but not identical. You are right to be concerned about it, but this particular red dot is to be expected and causes no problems.
Unread 13-02-2010, 08:36
Software Architect
Re: Camera servo
Do you have the 6v power jumper installed next to the PWM pins going to the servo?
Unread 13-02-2010, 09:36
Re: Camera servo
If there is compatibility then why isnt our robot responding? do i need to add a converter Vi in between that? or is there something else wrong with our code?
Unread 13-02-2010, 18:13
Programming Captain
AKA: Umang
Re: Camera servo
We got our camera servo working using axis 3.
to take into account the -1 to 1, the value given by the axis was divided by 4, and then added .5, so the total value would go from .25 to .75(since we dont need the camera to go up and down all the way)
2010
Unread 14-02-2010, 00:43
Software Architect
Re: Camera servo
I don't know why your robot is not responding. You haven't given enough information about how you're trying to make it do what you want it to.
Unread 14-02-2010, 01:26
ecnahc515 ecnahc515 is offline
FRC #3192
ecnahc515 is an unknown quantity at this point
Re: Camera servo
Make sure you have a jumper on the pwm channel your using for the servo.
Also I have a question:
Im using axis 3 as a throttle to control the speed for our robot. Basically I wana be able to move it down to make our robots motors run slower so going over the bump isnt so fast and reckless.
I did it with controls, but I wana do this with the actual axis 3 button.
How would I go about doing it. These two are what I have:
Unread 14-02-2010, 23:12
Programming Captain
AKA: Umang
Re: Camera servo
That wasnt the problem. Our original code had button 2 moving the camera up and button 3 moving the camera down, and that was not moving the camera for some reason. Without touching the electrical board, we changed the camera servo code so that it moves according to the values given by Axis 3, the camera started moving. I dont know why it didnt work before, but it works now, which is one less thing for us to worry about
2010
Programing servo in Axis camera 206 frcchile NI LabVIEW 6 18-01-2009 08:53
Camera servo trouble Demothesis Electrical 5 27-01-2007 17:15
Camera Servo Problems pi_guy578 Programming 2 28-01-2006 13:17
Servo Strain With Camera DanDon Motors 6 13-02-2005 08:49
Camera Servo Obi Programming 2 30-01-2005 17:09
