Uploading Code to the cRIO
Hi, its Team 3011 again. We're having an issue similar to whytheheckme and a kenny03, where NetBeans outputs the following text when we attempt to run the program:
[cRIO] GCs: 1 full, 0 partial [cRIO] ** VM stopped: exit code = 1 ** [cRIO] task 0x2151cb8 (SquawkRobotTask) deleted: errno=0 (0) status=1 (0x1) Their problems seem to have been solved by updates, but that won't work for us. We have the latest versions of the software, and the code was running fine. Key word "was". One of our programmers had, unbeknownst to me, imaged the 'bot with the code. Not knowing this, I ran the code out of Netbeans as usual, and then stopped it when I looked at the driver's station and saw that there was already robot code. Now the entire thing seems to be FUBAR, but the sample codes do work. I honestly have no idea what to try now, so can anyone help us? |
Re: Uploading Code to the cRIO
This is a pretty big issue with only 2 weeks left during the build season, Could anyone help us out with this?
Moderators can close this thread. It turns out that our Chief Programmer (who just got back) had left something in the code that we didn't catch. He solved it in ~5 seconds.
Our team is also having the same problem. Can you tell us what you guys changed to make it work?
| uploading source onto cRIO?! | NetSkay | Programming | 5 | 01-13-2012 07:41 PM |
| Code suddenly stopped uploading? | sp33chy | Java | 2 | 02-08-2010 06:53 PM |
| Problem uploading code from a VM | LinuxMercedes | C/C++ | 5 | 01-12-2009 11:31 PM |
| "Battery: No Code" after uploading .out file to cRIO | knine143 | FRC Control System | 1 | 12-20-2008 10:14 PM |
| Uploading Old Code | G1279 | Programming | 1 | 01-12-2008 10:35 PM |
