Go to Post This may not be Battlebots but it sure isn't Pretty Pretty Princess Bots. - Andrew Schreiber [more]
Unread 13-02-2010, 09:22
kavisiegel kavisiegel is offline
FRC #0061 (The Shifters)
kavisiegel is an unknown quantity at this point
cRIO requires independent restart from the robot to connect
So this is an odd problem that we haven't even begun to get an edge on. I'm hoping this is one of those simple issues that you just can't find on google because of the wording.
Basically, what's happening is when we turn the robot on, the driver station sees the bridge and not the cRIO. Even after half hour of waiting, it still doesn't see the cRIO until I walk up to the robot and push the reset button on the unit its self. At that point we're online in about 10-20 seconds.
I'm concerned about what we'll do in competition, clearly we won't be able to run onto the field to get to the reset button.
www.team61.com
Cannot connect to cRIO from WindRiver Darkknight512 C/C++ 8 25-01-2011 19:42
How to connect the 12v solenoid to the cRIO and spike relay? hannigan Pneumatics 3 13-02-2010 09:21
Can't connect your imaging tool to the cRIO? jman1783 Control System 0 24-01-2010 14:07
How to connect the Workbench with the cRIO? kentschool C/C++ 3 28-12-2009 16:03
