Go to Post From past experience members of our team insist on never trusting gravity. - Vash [more]
Unread 13-02-2010, 10:34
mark.amber mark.amber is offline
FRC #2039
mark.amber is an unknown quantity at this point
Can I use slot 6 for digital module in JAVA?
port four is ruined, any help is appreciated.
if it is easier you can pm to call on phone.
Can one Using java use module 6 for the drive system?
Thanks,
Mark Amber
Unread 13-02-2010, 10:53
FRC #2039
Re: Can I use slot 6 for digital module in JAVA?
seems as one might be able to
http://www.chiefdelphi.com/forums/sh...ad.php?t=80729
we will try, I will move to that thread.
Unread 13-02-2010, 10:54
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You should be able to use slot 6. However, <R59> requires that you use slot 4 for the RSL. You should call NI.
Unread 13-02-2010, 10:56
FRC #2039
Thank you! (You beat me to the solution, I just posted my own)
We will have a good crio for the compitition, but it will work for testing at least!
Thank You!
Mark Amber
Using cRIO slot 8 as a digital module? CapnKernel FRC Control System 1 06-02-2010 22:57
Ribbon Cable between Digital Module and Sidecar? manderson5192 Control System 3 29-01-2010 09:42
Changing Crio Digital Sidecar input slot from slot 4 to 5 Trevor_Decker Java 9 28-01-2010 12:29
Where can I find camera tracking code for Java? nikRbokRz Java 4 20-01-2010 23:35
Open motor reference on Slot 6 DIO Module trilogy2826 NI LabVIEW 2 27-01-2009 08:42
