Go to Post All this is sounding like gobbly-de-gook but it is important to understand this gobbly-de-gook. - ebarker [more]
Unread 13-02-2010, 10:44
PapaRobocat PapaRobocat is offline
FRC #2161
PapaRobocat is an unknown quantity at this point
Belt Material
How do you alter the size of drive belting? We tried heat and that makes it crumple. Thank You
Unread 13-02-2010, 10:54
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Rookie Year: 2007
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: Belt Material
What you can do to change belt sizing depend on how your drive belt is fabricated.
See http://www.mulhernbelting.com/belt_fabrications.php
If your belt uses a splice you can undo the lacing/metal fastener you can undo the connector and slice a little bit off the belt and then reproduce the splice.
If your belt is endless or uses a splicing method you can't reproduce in your shop (based on your original post this seems likely). Then you need to add a tensioning pulley to your drive train. This mean that you need to add a pulley in a position that makes the pulley tight (bonus points if you make it adjustable). There are numerous threads here on CD on how to do it.
Belt material Michael Leicht Technical Discussion 1 15-01-2009 21:14
Broken Belt m3ch4num470r Technical Discussion 15 21-08-2008 10:28
Conveyor Belt Setsanto 3D Animation and Competition 2 21-01-2008 20:51
[OCCRA]: Belt material and wheel modification JBotAlan OCCRA Q&A 1 19-09-2007 21:15
type of material; conveyor belt Alyssia General Forum 9 10-01-2003 13:06
