cRio Communications Fail
We've just recently updated everything with the new updates (NetBeans plugin, DS and cRio image), but when NetBeans tried to download code to the cRio, it fails. It appears to be looking for version 19, but we have version 20.
The similar error happened earlier on, but the was a matter of updating the cRio and not NetBeans. This time I'm pretty sure NetBeans needs an update. I don't think I missed any of today's updates, but maybe I did. Anyone have any thoughts? |
Re: cRio Communications Fail
There is some xml file in the netbeans folder where if you change some text that ends with "v19.zip" to "v20.zip" it all should work. The search function is your friend
| bridge/cRio communications sporadic | nathanww | FRC Control System | 23 | 22-02-2010 15:00 |
| Camera Config Fail. | Thundr Whale | Programming | 4 | 13-02-2010 13:32 |
| Solenoid is teh fail | Nick Seidl | Pneumatics | 23 | 25-01-2010 13:07 |
| cRIO communications problem | alex42 | FRC Control System | 5 | 16-01-2010 20:22 |
| DS and cRIO Not Maintaining Communications | Will_Sica | FRC Control System | 0 | 10-01-2009 13:39 |
