Go to Post ... Better to treat everything like it's about to explode and be wrong than the other way round. - Bongle [more]
Unread 13-02-2010, 13:09
brianelite brianelite is offline
FRC #2898
brianelite has a spectacular aura aboutbrianelite has a spectacular aura aboutbrianelite has a spectacular aura about
Camera causes code to fail when deploying/running on robot
You can see the only line of code making reference to the camera in the screenshot.
Has anyone else seen this? Anyone know a fix?
The code deploys/runs fine without that line of code, but cannot run or deploy with it... It seems there is a problem with the camera library or our library config...
Unread 13-02-2010, 18:59
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: Camera causes code to fail when deploying/running on robot
Do you have WPILib 4, 4.1 or 4.2 and cRIO update v19 or v20?
I got this error after updating from 4 and v19 to 4.2 and v20
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 13-02-2010, 20:36
FRC #2898
4.2 and v19... where do you get v20?
I went back and applied all the patches again (in order) and then this error started appearing... I did this because the camera code wasn't deploying to the robot... now I can deploy and run non camera code... but do nothing with anything camera related...
Unread 13-02-2010, 20:43
byteit101's Avatar
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1534
from usfirst.org/frccontrolsystem
it doesn't show it, but there are DS and Labview (and therefore new images, in this case v20) updates. this page is slow to update
Watchdog.Kill();
Unread 13-02-2010, 20:53
FRC #2898
Ok - I will check to see if that has been applied...
How did you get rid of the error?
Unread 13-02-2010, 21:32
byteit101's Avatar
haven't yet, the meeting ended before I got a chance to work on it (and we were all excited making the robot drive)
I will see what I can do tommorow
Watchdog.Kill();
Unread 14-02-2010, 11:50
KRibordy KRibordy is offline
FRC #1000 (Cybearcats)
KRibordy is an unknown quantity at this point
Look into the AxisCamera.h include; they changed some of the function names. In addition to changing the functions to camel case, I'm pretty sure they changed the name of the GetInstance function entirely. Looking into that Vision/AxisCamera.h should help.
Also, if you haven't done it, I think we had to change the include in the main file from AxisCamera2010.h to AxisCamera.h
Unread 15-02-2010, 01:13
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Please see:
http://www.chiefdelphi.com/forums/sh...d.php?p=920299
and/or
http://www.chiefdelphi.com/forums/sh...ad.php?t=82314
and/or
http://forums.usfirst.org/showthread.php?t=14573
These threads all describe similar issues to what you are reporting.
Compressor Code causes No Robot Code Error sircedric4 C/C++ 25 03-02-2010 10:13
LabVIEW code deploying instead of running linkhyrule5 NI LabVIEW 6 10-01-2010 14:57
Running camera code wirelessly windell747 NI LabVIEW 4 09-02-2009 21:27
Problem deploying/running default code blaxbb FRC Control System 0 10-01-2009 11:59
Presence of function causes auton to fail??? Kyveck Programming 13 16-02-2006 14:48
