Go to Post "If you abuse the easy button, you become it." / "What does that mean?" / "We hit you and you say 'That was easy'" - ScoutingNerd175 [more]
Unread 13-02-2010, 16:47
z.s.tar.gz z.s.tar.gz is offline
FRC #3242
z.s.tar.gz is an unknown quantity at this point
Can not connect to cRIO
We are trying to run the sample robot code, but we keep getting this:
Code:
Error connecting to 'VxWorks6x_10.32.42.2' (Registry localhost). Failed to launch target server
Possible casused by: back-end not connected
Remove dead entry from registry!
What could be causing this?
Unread 13-02-2010, 17:41
Chasegd128 Chasegd128 is offline
FRC #0128
Chasegd128 is an unknown quantity at this point
Re: Can not connect to cRIO
We had the same problem. We re-imaged the cRIO and it then decided to work. So your best bet would be to re-image it. Good luck!
Unread 13-02-2010, 19:06
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
are you physically connected to the robot?
good battery?
correct network settings?
there are probably more reasons this could come up, but those are the three most common
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Cannot connect to cRIO from WindRiver Darkknight512 C/C++ 8 25-01-2011 19:42
Any way to connect to console on cRIO? SteveGarward C/C++ 10 05-02-2010 07:28
Cannot connect to cRIO aybose Java 3 02-02-2010 22:20
cRIO Does Not Communicate, Yet Can Be Pinged and Re-Imaged 1951-44U FRC Control System 7 15-12-2009 21:25
Can not connect bridge and router wirelessly team877 Programming 4 08-01-2009 00:18
