Go to Post Remember, GP doesnt just need to apply to FIRST; if we all apply in our lives as a whole, the world will be a better place. - Dillon Compton [more]
Unread 16-02-2010, 22:55
sp33chy sp33chy is offline
FRC #3332
Rookie Year: 2010
sp33chy is an unknown quantity at this point
Re: Stuttering compressor
Interesting, the watchdog wasn't complaining on the dashboard however. Maybe I just fed the watchdog a step too late which wasn't enough to show up on the dashboard but was enough to make a difference.
So to any teams having this issue: try feeding your watchdogs more often.
Unread 17-02-2010, 23:16
SteamChief's Avatar
SteamChief SteamChief is offline
AKA: Science Teacher / Engineer
FRC #1546 (Chaos, Inc.)
Team Role: Coach
SteamChief is an unknown quantity at this point
We had the same issue the other day. For some reason, the problem seems to have corrected itself. No changes in programming were made. While we were having the problem, we changed batteries, thinking it may be a voltage/dying battery issue. A freshly charged battery made no difference.
Unread 13-02-2010, 17:38
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Originally Posted by sp33chy View Post
I'm wondering if it is normal that when the compressor gets to 115-120psi it kind of does a small stutter instead of turning off completely (the pressure does not continue going up however).
No, that's not normal, unless you have a fast air leak.
Normally, the pressure switch goes on when the pressure drops below 95psi and turns off when it gets above 115psi. Then doesn't turn on again until it again falls below 95psi.
What does the gauge show?
Unread 16-02-2010, 18:59
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Your wiring looks fine.
Have you measured the resistance across that pressure switch like I mentioned before? It is possible that your switch is defective. That switch should open (resistance jumping to infinite) when the air pressure reaches 115psi, and it should close once again (resistance jumping to 0) when the pressure drops below 95psi.
Aren't signatures a bit outdated?
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
compressor maxgebhardt Pneumatics 14 17-01-2004 08:22
compressor Greg Needel General Forum 2 14-02-2003 07:50
Compressor TwoEdge47 Pneumatics 5 04-02-2003 22:41
Compressor agenova Programming 4 22-02-2002 21:44
