Servo Range-of-Motion?
What is the range of motion for the servos? I cannot find it anywhere.
Thank you for any help. |
Re: Servo Range-of-Motion?
I believe it is 170 degees around.
Thank you, although that seems a bit high. Just to clarify, I'm talking about the effective angle you can command it to, not the full mechanical range you can turn it to.
i believe it is 180 and all angles are applicable. we use ours that full range with no problems
180? Okay, that seems about right. However, I didn't think they went quite that far. 170 was my guess. I'll look at ours, maybe there are differences. I can tune it with the camera, anyway.
Thank you for the help. |
The standard camera servos are 170, as shown by the centerpoint of 85 in the camera software. Most standard servos are 170 or 180.
I guess I'll use 170 for the angle.
Thank you for all the help. |
| range sensor | elvin23 | Programming | 2 | 04-02-2008 20:40 |
| Finding range | DanDon | Programming | 11 | 10-01-2006 22:58 |
| Servo behavior question / advanced servo/PIC programming question | DanL | Electrical | 12 | 18-10-2005 18:33 |
| servo range of motion | tux | Control System | 4 | 07-05-2005 02:32 |
| ir beacon range | doy | Programming | 10 | 29-01-2004 16:46 |
