Go to Post Inspiration and recognition does not equal "advanced shop class". What's better for your team is not better for all teams. Remember that. - DonRotolo [more]
Unread 13-02-2010, 21:59
llama1719 llama1719 is offline
FRC #1719
llama1719 is an unknown quantity at this point
Angry Netbeans installation not clear
I'm trying to install the java plugin for netbeans. I'm following the directions of the "Getting Started with Java" pdf booklet from the website. I installed the plugin successfully, but I'm trying to do steps 9 and 10. They are:
"The plugins are installed; a little configuration is required.
9. Select “Tools” menu, and choose the “Options” menu options, from the NetBeans menu bar.
10. Select the “Miscellaneous” tab. Then select the “FRC Configuration” tab and enter your team number into the text field. Then press OK."
I have no idea what it means when it says choose the options menu options from the netbeans menu bar from the tools menu. Can somebody please help me do these two steps?
A note: I'm running this on Mac OSX.
REMINDER : NetBeans not talk to the CRIO cilginbilgin Java 1 08-02-2010 16:14
NetBeans not talking to the cRio scottbot95 Java 21 07-02-2010 14:19
Downloading code: Netbeans does not reset cRIO ellisk Java 8 31-01-2010 19:02
Is 9.3.9 clear to you? soap108 Rules/Strategy 2 12-02-2007 18:10
Clear Screen cprogrammer Programming 6 28-01-2007 22:20
