[FTC]: Servo Help Please!
I don't know how to program servos in RobotC. I haven't had the need to for the last few weeks.
What I'm trying to do is when button 1 is pressed servo1 turns and lets a ball drop into the catapult then the servo moves back to stop the balls. Then when you press button 2 a servo holding down the catapult releases, servo 2 stays in that position while the catapult goes. After the catapult is at the top servo 3 has a bar on it and brings the catapult back down and servo 2 locks it, servo 3 then moves back to its original position. can someone help me understand programming servos in RobotC or give me a link to somewhere? Thanks ![]() |
| [FTC]: LABView Servo Problem | Geek_Girl | FIRST Tech Challenge | 9 | 16-02-2009 19:29 |
| [FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo Prob | PackersFan | FIRST Tech Challenge | 11 | 26-01-2009 21:25 |
| [FTC]: Servo Reversing? | teamN20 | FIRST Tech Challenge | 0 | 26-11-2008 14:17 |
| [FTC]: Servo Question | roborat | FIRST Tech Challenge | 1 | 04-11-2008 18:29 |
| [FTC]: FTC Servo-Motor Problem with Labview | dnhansen | FIRST Tech Challenge | 1 | 26-10-2008 00:43 |
