Go to Post [when asked where to learn about robot parts] ...some forum called Chief Delphi. I hear the people there are pretty knowledgeable about this robotics thing. - EricH [more]
Unread 14-02-2010, 11:31
drwisley's Avatar
drwisley drwisley is offline
FRC Coach
AKA: Dave
FRC #1756 (Argos)
Team Role: Coach
Rookie Year: 2007
drwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant future
Dual Mecanum
Has anyone tried stacking mecanum wheels? I'm curious to see if it improves strafing control. We have a few years of experience with mecanum and haven't been able to strafe quickly without drifting one way or the other.
Unread 14-02-2010, 12:24
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Re: Dual Mecanum
As far as I know there is nothing preventing Mecanum wheels from working in pairs.
For example you could have a 8WD with the front two sets acting as a traditional Mecanum set and the back pair acting as a Mecanum set. In this set up you would have two X's (from the top side -- see this thread)
The first and 3rd wheels should be driven together and the 2nd and 4th wheels should be driven together.
A problem will be do you lower any of them? I suppose that if you do, you'd lower the 1st and 4th rows otherwise you'd effectively have the middle pair on the ground forming an O from the top. Which is bad because you won't be able to spin effectivley (again see this thread)
Another alternative is to have this config:
BUT... The more I think about it, the more I believe the question is the wrong question.
Wrong question: "Has anyone tried stacking Mecanum wheels?"
Right question: "How can I go sideways with Mecanum wheels more effectively (= fast and straight)?"
The answer to that I think is two fold.
#1 keep your CG in the middle of the machine (as much as you can) and
#2 feedback loop using an angular rate sensor*
With these two steps I believe you can get what you want without having to resort to dual Mecanums.
Cheers,
Joe J.
*often called a "gyro" for historic reasons involving the means that angular rate sensors were implemented prior to MEMs electronics. Like the confusion between "power" and torque, I wish the world were otherwise, but I will just add it to the list for the time being and move on...
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 14-02-2010, 14:06
drwisley's Avatar
FRC Coach
AKA: Dave
FRC #1756 (Argos)
Team Role: Coach
Rookie Year: 2007
Re: Dual Mecanum
Thanks for the quick and thorough response Joe.
We have always focused on suggestion #2, angular rate feedback, and have never made a conscious effort to balance the normal force between each wheel. I have rarely had the luxury to, in the past I'm always trying to remove weight where ever possible.
Intuitively, I figured decreasing the vibration amplitude in half and consequently doubling the frequency by using dualies would improve strafing drift. I'll definitely try out tip #1 first.
Thanks again,
Dave
Unread 14-02-2010, 15:32
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Dual Mecanum
I'd have to agree with Tip #1 from Joe. Back in 2005, 330 tried mecanum on an experimental basis. One of the tests was how well we could go sideways with a tetra [8lbs] about 2' from the robot on a pole. Let's just say that the robot did a nice sideways arc.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Dual Robots ChrisMcK2186 Rules/Strategy 15 08-01-2008 15:42
Dual majors? Lisa Perez Career 21 18-05-2004 22:24
pic: 716 Dual Motor/Dual Speed CD47-Bot Robot Showcase 18 23-04-2004 01:51
White Paper Discuss: Dual-motor, dual-speed gearbox CD47-Bot Extra Discussion 8 05-04-2004 19:24
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
