Go to Post What I want is to ultimately make it so that the programming is actually done before the robot is finished. Imagine that! - Danny Diaz [more]
Unread 14-02-2010, 16:51
SidneySalvo SidneySalvo is offline
FRC #1691
SidneySalvo is an unknown quantity at this point
Need a mentor to help with general issues
Hello, I'm the head programmer for team 1691, and with a week left before ship date i'm having some serious problems running a program.
I am having problems with downloading the program from my classmate to the cRIO wirelessly, and when i download the program tethered, and set to run as startup, when i go to the DS it says "No Robot Code". I've gone through several manuals and searched the site but no one that i have found seems to be having the same problem as myself.
If there is some kind soul out there that would be willing to spend a few hours on the phone with me sometime this next week and attemp to work through my problems, I would be forever grateful!
Also if anyone has any advice they might give as a reply on here, that would be great.
If interested in possibly attempting to help me email me at:
techpreist2.0@gmail.com
The Universe is filled with magical things, patiently waiting for our wits to grow sharper.
Unread 14-02-2010, 18:09
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Need a mentor to help with general issues
First advice: make sure you have updated both LabVIEW and your Driver Station to the proper revisions. http://www.usfirst.org/frccontrolsystem has links to the updates.
Second advice: if you're using the Classmate for software development, make sure to run the Driver Station application under the Developer account while you're actively programming. It's a lot faster than logging off and logging back in under the Driver account, and it's a lot safer than logging on as both Developer and Driver at the same time with fast user switching.
Third advice: you'll get better help if you have specific issues than if you have general ones.
Unread 14-02-2010, 18:42
FRC #1691
1: I have updated both labview and the driver station and after both of those, I reimaged the cRIO as well.
2: I'll try opening the DS in the developer account but it really doesn't take too long to log off and log on the other.
3: The specific problem is that when i download the project to the cRIO and attempt to the run the code in the driver station, it says "No Robot Code" and i would like to know if there is something that i need to change in the program to maked the DS recognize it.
Thank you for your help i'll try to be more specific next time
I did get the wireless problem worked out though and ti will now download with no problems.
Unread 14-02-2010, 22:05
Software Architect
I'm not sure what "run the code in the driver station" means. What are you doing in order to download the project to the cRIO?
Unread 15-02-2010, 01:18
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
Strange issue.
Have you built the startup application before deploying it as startup?
I'm assuming you have, but I wanted to check.
Also, are you using update #2, or #2.1? I haven't tried #2.1 yet, so I don't know what issues there may be with it.
-- Marshal Horn
NEED GENERAL HELP on how to find programming and animation resources delphi demon General Forum 1 02-04-2007 15:58
Need Help With General Pneumatics Ryan O Programming 7 24-01-2007 21:31
pic: Weight Issues?! Need help! robodude03 Extra Discussion 12 24-01-2006 17:16
General Help With Programming lt744 Programming 2 02-12-2004 17:09
HELP! Problem with General Dimension in Inventor 5. sanddrag Inventor 12 21-09-2003 21:46
