Go to Post Sweeeet swerve drive - Andy Baker [more]
Unread 14-02-2010, 17:12
Randy Forgaard's Avatar
Randy Forgaard Randy Forgaard is offline
Parent 1729, former mentor 3126
FRC #7129
Team Role: Parent
Rookie Year: 2010
Randy Forgaard is a splendid one to beholdRandy Forgaard is a splendid one to beholdRandy Forgaard is a splendid one to beholdRandy Forgaard is a splendid one to beholdRandy Forgaard is a splendid one to beholdRandy Forgaard is a splendid one to beholdRandy Forgaard is a splendid one to behold
Using a PWM cable splitter for 2 Jaguar motors
We are using one of the AndyMark gearboxes that allows the use of 2 CIM motors at one time for extra driving power on a single side of the robot.
We are starting to run out of PWM channels on the Digital Sidecar, and we would prefer not to use a second Digital Sidecar, to save on some space.
One possibility is that we could use an off-the-shelf PWM servo splitter cable, so that one channel of the Digital Sidecar could control both CIM motors that are used in a single gearbox, since both CIM motors need to receive the same signals anyway. Then, we would simply program our robot as though it has two motors (one on each side) rather than four motors.
Can anyone think of a reason why we shouldn't use a PWM splitter cable for this purpose? In this thread of the Q&A forum, the Game Design Committee says that there is no rule saying you can't do this, but they suggest there might be better technical alternatives.
Any thoughts, yea or nay? Many thanks!
Using the same Jaguar/Controller for Joystick and buttons.... mck567 NI LabVIEW 2 09-02-2010 16:34
Put a Jaguar PWM cable on electric break switch? wt200999 Technical Discussion 2 21-01-2009 16:55
Using Kevin's PWM outputs for a quieter drive system. PhilBot Control System 20 09-03-2008 16:10
Must Connect PWM cable in reverse for victor to work? Leav Electrical 3 12-01-2005 16:43
PWM Cable Clip for Victors sanddrag Technical Discussion 9 18-07-2004 19:27
