Go to Post If this isn't filmed in a Tim Hortons then I'm going to be severely disappointed. - marshall [more]
Unread 14-02-2010, 19:09
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Rookie Year: 1998
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking ASP.NET 2.0 & SQL
I am trying to design a web form that will insert collected data into a sql database when the submit button is clicked. At the moment I have the results being e-mailed to someone who than manually enters the data into a database. I'm using Visual Web Developer 2008, SQL 2005, and ASP.Net 2.0 VB coding.
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 15-02-2010, 20:49
Scott L.'s Avatar
Rookie Year: 1998
Talking Re: ASP.NET 2.0 & SQL
Got that part working now. Have a new problem/ question.
How do I design a custom validator to check if a value typed in a particular field already exists in the database. Currently an error is returned about the PK already existing.
SQL Ehsan Programming 2 12-10-2006 14:08
STAMP .sql files to share? copertop Scouting 2 22-03-2006 17:16
ODBC SQL Problem LBK Rules Website Design/Showcase 1 18-06-2004 23:29
PHP or ASP.Net? Greg Website Design/Showcase 37 26-07-2003 02:29
